Old 04-22-2016, 06:59 PM   #1
chrismoore701
chrismoore701's Avatar
Powder coating rim issues
I got a call from a pretty reputable powder coating place on the south side of Chicago where I dropped my rims off. Standard rally. They said that due to the outer rim heating at a different rate than the center piece that bubbles formed in the powder coating at the joint between the two metals. They said they will sand blast coating off at no additional charge so I can paint it. Not happy. Anyone ever heard of this before?
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 04-22-2016, 07:39 PM   #2
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Lightbulb Re: Powder coating rim issues
I'm no expert but it sound's like BS to me.... I'm thinkin that maybe there oven isn't working properly or they placed your rim's too close to the heat source IE the element.
Oh BTW I would only pay them for the sandblasting job like 80 bux! Cuz that's all they did.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 04-22-2016, 08:48 PM   #3
franken
I'll bet if I go out, lay on the ground and look closely at mine I'll see some bubbling at that spot as well. I'm not sure the reason they gave is accurate, since steel and steel should probably heat at the same rate. I'd guess its junk that didn't get removed in the cleaning process.
You might want to ask the internet. I hear you can search for stuff...
Old 04-22-2016, 08:58 PM   #4
chrismoore701
That why I have you guys. Your better than the Internet
Chris
Old 04-22-2016, 10:09 PM   #5
BLT gmc
My brother-in-law runs/owners NorCal Powderhouse. He has had these problems with rims that are pieced together. He states there is oxide, debris, chemicals in microscopic levels in those cracks. He combates the problem with multiple bead blasting passes, multiple heating cycles and lots of luck/prayer.
BLT gmc is offline   Reply With Quote
Old 04-22-2016, 10:28 PM   #6
80SPORT
80SPORT's Avatar
We have had this issue before ;for the daily drivers we did not worry about it;for the restored trucks we painted the rims after media blasting ....solves the problem and looks more original.
80SPORT is offline   Reply With Quote
Old 04-23-2016, 07:45 AM   #7
chrismoore701
So based off this article. It is more common than we think
http://powder365.com/forum/viewtopic...cb6f1b4b68ebf7
I will see how it looks and argue from there. They never warned me. My dad had this same thing happen on the ralleys on his 63 vette. Hard to see but he was not happy just thought it was a sloppy job. It looked just like the first pics in the article. If that is all the bad hey are I will be ok with that. But still going to argue the price down. But at least they did tell me what happened and I need to plan for the worse
Chris
Old 04-23-2016, 03:50 PM   #8
Kaysen
Good info since I'm about to redo a set of rally's. I think I'll just go with paint for sure after seeing this
Kaysen is offline   Reply With Quote
Old 04-25-2016, 07:39 AM   #9
riz
It makes sense to me. Different metals WILL heat differently. Plus, there is a shallow groove where they meet were powder coating could pile up in and bubble due to the excess or extra coating that fills that gap. I had my ralleys done and they look great BUT I bet the area they talked about MAY not hold up in the long run...... only time will tell.
RIZ
riz is offline   Reply With Quote
Old 04-25-2016, 11:58 AM   #10
chrismoore701
Will see. Hoping it is a small issue that I will deal with. I heard painting will discolor with the heat from the breaks. Going to pick them up soon. Just ordered my tires. So hope they are not worse than I am expecting
Chris
Old 04-25-2016, 04:19 PM   #11
chrismoore701
Well the rims are trashed. At least they owned up to the issue. They are going to dip them and strip the coating back off to bare metal. No charge for anything. He did apologize as they should have warned me. So I am going to paint them. Look how bad the bubbles are
Chris
Old 04-25-2016, 05:05 PM   #12
allengator
allengator's Avatar
hey... at least they are taking responsibility...
Props for that!!!
Allengator
Outta the Blue
(my band - available for hire in the DFW area!)
1980 Chevy SWB Pickup (build thread)
1951 Chevy Sedan Delivery
2004 Chevy Tahoe Z71
2011 Harley Davidson Street Glide
2018 Silverado Z71 Crew Cab
allengator is offline   Reply With Quote
Old 04-25-2016, 07:23 PM   #13
chrismoore701
Props for that!!!
Agree. I think I am just going the rattle can route. So this is not a bad thing. $300 down to $12. And free stripping. Would rather have powder coat but hey. What are you going to do?
Chris
Old 04-25-2016, 10:14 PM   #14
chrismoore701
So I was on my way back from picking my mother in law up at the airport when I ran across an Eastwood store. I knew it was up there but didn't know where. Spun a uturn and left the mother in law in the truck and did a little shopping. 3 cans of argent silver and 2 cans of clear. Now just need to wait to get the rims back and paint them
Chris
Old 04-25-2016, 10:51 PM   #15
Kaysen
I did a set today. Sandblasted, made sure to get the remaining sand out of the seam with a razor blade, primed, painted the backs and tire surfaces semigloss black, then did the faces last. Really happy with how they turned out. I didn't go with any of the argent I found as it all seemed too dark for me. I matched up some duplicolor rattle can to a spot that was covered with a wheel weight so I'm pretty sure it's close. I'll put 2-3 coats of clear on tomorrow with a spray gun and call them done.
Old 04-25-2016, 10:52 PM   #16
Kaysen
Forgot the picture!
Old 04-25-2016, 10:54 PM   #17
chrismoore701
Nice nice
Chris
