Old 04-20-2016, 11:36 PM   #1076
lower50's
lower50's's Avatar
Re: 1949 Chevy 3600 into a daily driver
You make really cool tables.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 04-21-2016, 09:34 AM   #1077
Coach529
Coach529's Avatar
Thanks!! It is a hobby I have done for about 4-5 years.
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 04-21-2016, 10:34 AM   #1078
Coach529
Coach529's Avatar
Busy night in the garage.
I had some help and we got the bed sides cut out for the wheel and UCA clearance and got the bed mounted.
I did not anticipate removing so much material. The bedsides clear the tires now but just barely. I will probably take out a bit more to have some clearance. I will also have to remove some of the fender flange.
1949 Chevy 3600
Old 04-21-2016, 09:22 PM   #1079
Advanced Design
Advanced Design's Avatar
Coach, I really like those tables! Very nice. Good to have friends to help out with the heavy lifting.
Advanced Design is offline   Reply With Quote
Old 04-21-2016, 09:42 PM   #1080
Coach529
Coach529's Avatar
Spent a couple hours tonight finishing up the bed sides and mounting the rear fenders. Loving what I am seeing!!
1949 Chevy 3600
Old 04-21-2016, 11:07 PM   #1081
lower50's
lower50's's Avatar
Yup that looks really nice.
1951 MG TD
Old 04-22-2016, 01:11 AM   #1082
joedoh
joedoh's Avatar
the double camber is just doper than a meth lab
Old 04-23-2016, 02:18 PM   #1083
Coach529
Coach529's Avatar
Thanks guys!!
1949 Chevy 3600
Old 04-23-2016, 10:15 PM   #1084
youngrodder
youngrodder's Avatar
Looks great......laaayed out
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 04-24-2016, 09:57 AM   #1085
Coach529
Coach529's Avatar
Marc
I have found myself just standing in the garage staring at him...........
1949 Chevy 3600
Old 04-24-2016, 10:26 AM   #1086
solidaxel
solidaxel's Avatar
Take credit, YOU built it !
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-24-2016, 10:11 PM   #1087
youngrodder
That's the best part when you bolt parts back on after bagging it. I remember doing the same thing with my 48. You spend so much time visualizing how it will/might look, that when you finally see it you keep looking to make sure your not dreaming it....ha ha
Old 04-25-2016, 09:31 AM   #1088
Coach529
Coach529's Avatar
Exactly.
1949 Chevy 3600
Old 04-25-2016, 06:42 PM   #1089
lower50's
lower50's's Avatar
Best part about it for sure!!
1951 MG TD
Old 04-26-2016, 10:18 AM   #1090
Coach529
Coach529's Avatar
Not much photo worthy to report. Getting everything wired up. Battery will be in an old Hamm's cooler in the box. Running battery cables, etc.
Relays for my compressors are under the seat with my stereo stuff.
Chasing some leaks in the air system. So far I have a couple in the fittings in the air tank,
1949 Chevy 3600
Old 04-26-2016, 10:41 AM   #1091
Advanced Design
That is a cool shot. No doubt you will be cruising soon.
Old 04-26-2016, 11:30 AM   #1092
dwcsr
Hollister Road Co.
dwcsr's Avatar
That looking pretty badass
Old 04-26-2016, 04:29 PM   #1093
lower50's
lower50's's Avatar
Leaks on your tank system are not good. Good luck! I have one on my drivers rear I can not find, no bubbles anywhere.
1951 MG TD
Old 04-26-2016, 05:52 PM   #1094
Coach529
Coach529's Avatar
The leak is between a couple fittings so I think there is hope. Tank openings are 1/2". I have a 1/2" Galvanized Street 45 degree fitting, then a 1/2" to 3/8" threaded reducer. The compressor leader hose threads into the reducer. I have a leak between the threaded reducer and the 45 degree fitting.
1949 Chevy 3600
Old 04-26-2016, 06:06 PM   #1095
joedoh
joedoh's Avatar
I have owned a lot of bagged trucks, chasing slow leaks, like when the tank goes empty overnight for example, is a good way to go insane. I started using an engine driven compressor so empty or full, I can leave in about 5 seconds. on a couple with electric compressors I just put a large ball valve on the tank and turn it off when I get out.
the rule of leaks is: once you have a leak you have an air ride system, and vice versa. keeps me sane!
Old 04-26-2016, 07:52 PM   #1096
youngrodder
A couple points to mention is it is critical that your air line is trimmed straight. The slightest angle can cause a leak.
Also when you insert your plastic air line into the fitting, push it in and the try to pull it toward you a couple times. This helps to seat the line. Tracing the system with a spray bottle full of soapy water helps to pin point trouble leaks.
I'm sure that I'm not telling you anything new just thought I would mention it as that helped a lot with leaks I had in my air system.
Looking great man...
Marc
Old 04-26-2016, 08:23 PM   #1097
Advanced Design
Good points here guys as I am only on my second bagged truck. My first one had leaks at the fitting on the valve block.
Old 04-26-2016, 09:15 PM   #1098
Coach529
Coach529's Avatar
WE HAVE PRESSURE!!
Fired up the compressors tonight. Quieter than I had thought they would be. Hit 140 PSI in about 2 min roughly.
1949 Chevy 3600
Old 04-26-2016, 10:09 PM   #1099
99 to Life
99 to Life's Avatar
On my 49hardtimes (sold) I'd be lucky to get 2 days without loosing air throughout everything. I had some older viairs on there and wouldn't yah know I replaced the leader hoses with check valves. Thing filled up way faster and also little to no leaks for two straight weeks!!! So if you start noticing you are taking longer to fill up or pop fuses for your comps or have leaks, replace those leader hoses!
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 04-29-2016, 09:26 AM   #1100
Coach529
Coach529's Avatar
So far I just have a couple leaks between the compressors and the tank. I think if I raise the tank up a bit I can eliminate a fitting which will help.
Hopping to drop him down tonight off the jacks stands and see if I have any leaks between the switches and the bags.
1949 Chevy 3600
