Old 04-24-2016, 01:16 AM   #1
Stokester
Cargo floor question!
I'm in the process of installing a new rear floor in my 72 blazer. I have old floor out and ready to install new floor. My question is there are 2 holes on each side of the front of floor. I believe they are for bolting the rocker box reinforcement plate. Do I need to weld some nuts on the floor before I install? The old floor did not have any bolts in those holes but PO had done some work already!!!!!!!!! Any advise would be great! It's a gmcpauls floor if that makes a difference! Thx again. Mike
Stokester is offline   Reply With Quote
Old 04-24-2016, 08:56 AM   #2
60case
Re: Cargo floor question!
On my 70 blazer the nut are in the next piece up. The panel that covers where the door latches bolts.
60case is offline   Reply With Quote
Old 04-24-2016, 11:27 AM   #3
Stokester
U da man!!!!!! Thx. Floor is going in!!!
Old 04-24-2016, 05:57 PM   #4
Stokester
Thanks for all the help guys! Had to bend lip up then bend back when installed! I also had to trim a 3/4" slot in b pillars so it would slide in. All holes line up perfect!
Old 04-24-2016, 07:08 PM   #5
lks dcvn
lks dcvn's Avatar
Wow! That looks really good now that it is all new metal.
Any words of wisdom for those considering a similar replacement in the future?
I see you floated the rear quarters with some braces at the rear to make way for the floor. Nice work.
How does it connect to the front floor step up area and the quarter panels? Seam sealer and bolts? Can't recall if that area was spot welded or not from the factory.
lks dcvn is offline   Reply With Quote
Old 04-24-2016, 11:53 PM   #6
Chad22873
Chad22873's Avatar
Looks like you got it done. Looks great. Anyone looking for a new floor should highly consider GMCPauls. It appears to have gone very well for you and it certainly did for me as well.
BR549
Chad22873 is offline   Reply With Quote
Old 04-25-2016, 08:01 PM   #7
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Nice work! Did the repro floor come with nutserts for the OEM factory spare tire carrier? Thanks, Pete
