Old 04-24-2016, 02:30 AM   #1
KQQL IT
At the body shop.
KQQL IT's Avatar
Finally got my 406 back!
See how fast I can put this together again. Almost a year at the machine shop.
Old 04-24-2016, 06:58 AM   #2
Jake Wade
Jake Wade's Avatar
Re: Finally got my 406 back!
Love the color, what color code is it?
Jake Wade is offline   Reply With Quote
Old 04-24-2016, 07:59 AM   #3
Willowrun
Willowrun's Avatar
Do you mind sharing the specs on the 406? I've had a never rebuilt 400 sitting on a stand for years that I swear I will build some day so always interested in what other people are doing with them.
Old 04-24-2016, 10:37 AM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
2009 dodge surf blue
Old 04-24-2016, 10:41 AM   #5
KQQL IT
At the body shop.
KQQL IT's Avatar
9.9:1 200 cc dart iron eagle head
Comp hyd roller 288° 1.52 roller rocker
Rpm air gap intake 850 dp holley
5.7 rod..
Has ran a 12.0xx e.t @4160 lbs
Is a riot to drive.
Old 04-24-2016, 11:33 AM   #6
TurboLS
You have any idea what that motor will Dyno at?
1976 C-10 Stepside
2005 Chevy Avalanche Z71
2008 Subaru Wrx - Modified Track Car
2012 Harley Davidson Fatbob Custom
My build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703077
TurboLS is offline   Reply With Quote
Old 04-24-2016, 03:43 PM   #7
Jake Wade
Jake Wade's Avatar
Challenger color?
Old 04-24-2016, 05:01 PM   #8
KQQL IT
At the body shop.
KQQL IT's Avatar
Challenger color?
Exactly.
Old 04-24-2016, 05:03 PM   #9
KQQL IT
At the body shop.
KQQL IT's Avatar
It ran 11.99 at 4160lbs before, so around 480-500 depending on which calculator you use.
But never been on a dyno.
Old 04-24-2016, 05:05 PM   #10
KQQL IT
At the body shop.
KQQL IT's Avatar
Before and now.
Old 04-24-2016, 05:41 PM   #11
Jake Wade
Jake Wade's Avatar
Love it! Hate to bombard you with questions but, what is that rear tire size, wheel width, and backspacing?
That's the look I am after.
Old 04-24-2016, 05:49 PM   #12
bh86
awesome transformation man!
bh86 is offline   Reply With Quote
Old 04-24-2016, 08:33 PM   #13
KQQL IT
At the body shop.
KQQL IT's Avatar
No worries, 15x10 3.5 bs but... should have been. 4.5 bs had to do surgery to fit the 325-50 drag radial
Old 04-25-2016, 11:48 PM   #14
KQQL IT
At the body shop.
KQQL IT's Avatar
Well it fought me all day Sunday. But this made it worth it.
Old 05-01-2016, 12:00 PM   #15
KQQL IT
At the body shop.
KQQL IT's Avatar
Well it's in, and time for the it's and bit's.
New transmission crossmember went in decent.
Finally got the new converter and new th400 together.
It's the last transmission my friend Rudy built for me before he passed, feels weird.
Had it since '08 as my spare.
Old 05-02-2016, 02:40 AM   #16
KQQL IT
At the body shop.
KQQL IT's Avatar
Under its own power, first time in a while.
Old 05-03-2016, 10:05 AM   #17
68post
Truck looks great, your crew chief looks young but won't take too long before being behind the wheel.
The converter looks stout , what's the rated stall, and what's the rear gear ?
Tim K.
84 K30 srw Silverado 454 auto
85 C20 350 C6P auto flatbed
94 K1500 lifted shortbed 350 4 bbl NV4500
68post is offline   Reply With Quote
Old 05-03-2016, 10:56 AM   #18
KQQL IT
At the body shop.
KQQL IT's Avatar
Spec rite out of California
http://www.specriteconverters.com
Billet front half 3200 ish nitrous converter
And has a 3.82 gear in it.
So far is way more efficient than the tci steel fighter that was in it.
Lost 500 rpm at 65 than before
Old 05-03-2016, 11:46 AM   #19
68post
Nice. That should Rock N Roll
Tim K.
Old 05-03-2016, 12:01 PM   #20
KQQL IT
At the body shop.
KQQL IT's Avatar
Hope so, was doing 1.67-69 60' before.
Worried I've hurt the 60' n/a but real curious how big of a shot it'll take out of the hole.
Old 05-22-2016, 03:42 PM   #21
KQQL IT
At the body shop.
KQQL IT's Avatar
Testing my patience.
Slip yoke was dripping, tried pulling the driveshaft out. Had to pry it off.
Turns out I burned the tailshaft bushing up running it on the rack with rear off the truck up.
And the drive line was too long, got that all fixed.
And back to the tuning.
Old 05-22-2016, 11:47 PM   #22
Woodyboat
Woodyboat's Avatar
That photo of the sunset in your rear view mirror is GORGEOUS!! It has a lot of emotion and mood. You have a good photographic eye.
Woodyboat is offline   Reply With Quote
Old 05-23-2016, 12:05 AM   #23
KQQL IT
At the body shop.
KQQL IT's Avatar
Thank you.
Some of my recent favorites.
Benicia bridge at night.
Old 05-23-2016, 01:25 PM   #24
Pontiac1976
Pontiac1976's Avatar
Very nice truck.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 05-23-2016, 02:50 PM   #25
68Timber
I know the pieces fit
68Timber's Avatar
Are you running caltrac's? I can't remember what you're doing to make that thing hook. Congrats on getting it going again.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
