Old 04-24-2016, 09:41 AM   #1
Redneck79
Redneck79's Avatar
Ex military truck gears
I'm thinking to buy an 1985 ex military K30 6.2 liter diesel, but I know that military trucks have a modified transmission with different gears.
This one is an automatic 3 gears, do you think it's a boring drive and I should change the transmission ?
Redneck79 is offline   Reply With Quote
Old 04-24-2016, 09:51 AM   #2
hatzie
Moderator
hatzie's Avatar
Re: Ex military truck gears
The CUCV axle gears are 4.56:1
The CUCV TH400 has the same gearing as the Civilian version.
Will you be running it on the highways or locally?
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 04-24-2016, 09:55 AM   #3
andrewmp6
Its got a diesel turbo 400 and is a 4.56 gear ratio all oem gm parts.
Old 04-24-2016, 09:58 AM   #4
GM72K10
Next!
GM72K10's Avatar
Nothing special about the trans in a CUCV, all TH400s
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 04-24-2016, 10:07 AM   #5
Redneck79
Redneck79's Avatar
I will run it mainly locally, I'm looking for something with a lot of torque for have fun, not for higways
Old 04-24-2016, 10:09 AM   #6
Redneck79
Redneck79's Avatar
Old 04-24-2016, 04:45 PM   #7
Alex V.
Alex V.'s Avatar
A diesel with 4.56's sounds like just the ticket, then.
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Old 04-24-2016, 05:10 PM   #8
Redneck79
Redneck79's Avatar
"Sound like just the ticket" ?
Sorry but I have not get
I'm from Italy and I don't understand all the slang
Old 04-24-2016, 05:40 PM   #9
Jeramy
Jeramy's Avatar
he means it will do exactly what you are looking for
1981 Silverado C10 LS/4l60e
My truck may be loud and ugly but I love her like bacon
Jeramy is offline   Reply With Quote
Old 04-24-2016, 06:06 PM   #10
Redneck79
Redneck79's Avatar
Good, thanks for the infos
Old 04-24-2016, 08:31 PM   #11
Alex V.
Alex V.'s Avatar
Sorry. What he said.
Alex V.
Old 04-25-2016, 04:06 AM   #12
Redneck79
Redneck79's Avatar
No problem
Old 04-25-2016, 12:34 PM   #13
daddyjeep
daddyjeep's Avatar
I didn't realize you were from Italy either. With your username and Avatar Would have never guessed. I didn't know there were rednecks in Italy.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 04-25-2016, 01:11 PM   #14
slotard
With a 6.2, TH400, 4.56 you'll be at very high RPM on the highway (unless you have significantly larger tires than stock). It'll work well at low speed though.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 04-25-2016, 02:33 PM   #15
Redneck79
Redneck79's Avatar
Yes, the tires are larger than stock, 36 BF Goodrich All Terrain, I show you some photos.
I was also wondering to put dually wheels on the truck, (I'm a dually fetishist) what do you think about ?
I could have problems to the rear axle ?
Old 04-25-2016, 03:05 PM   #16
KShortell
KShortell's Avatar
Great looking truck!
As an aside, my dad was project manager for the CUCVs back in the 1980s at the U.S. Army Tank-Automotive Command (TACOM). They had some early teething problems, but worked out the kinks early on. They're solid trucks. After all, they're Chevys!
Semper Paratus
KShortell is offline   Reply With Quote
Old 04-25-2016, 03:41 PM   #17
Redneck79
Redneck79's Avatar
I want to add spike lug nuts, do you can suggest me a link where I can buy the right ones for the truck ?
Old 04-25-2016, 11:22 PM   #18
slotard
I imagine you'd need a flatbed in order to fit dually 36s. The internals of the rear axle are the same for 3/4 ton, 1 ton SRW, 1 ton DRW, and CUCV truck (which I think is just a 1 ton SRW). However, the DRW axle is wider. I'm not sure if you could fit dually rears with the axle you have, seems unlikely with the tire size you have. Additionally, the front setup is wider... I'm not sure whether it's the center section or just the hubs on squares, I know modern trucks it's the center section but someone said it was just the hubs on squares.
1973 C20, 350/350
Old 04-26-2016, 10:37 AM   #19
hatzie
Moderator
hatzie's Avatar
Some M1028 and M1031 CUCV can be found with dual wheels. It was a motor pool add on kit for the M1028 & M1031 making it an M1028-a2.
http://67-72chevytrucks.com/vboard/s...d.php?t=546148
Old 04-26-2016, 11:09 AM   #20
walkerb
walkerb's Avatar
I was also unaware!
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 04-26-2016, 08:49 PM   #21
GM72K10
Next!
GM72K10's Avatar
Dually CUCVs
M1028a2 NP205 converted M1031 or M1028a1
M1028a3 NP208 converted M1028
86 K30 CUCV M1028A1
Old 04-30-2016, 07:04 AM   #22
Redneck79
Redneck79's Avatar
Originally Posted by GM72K10 View Post
Dually CUCVs
I found this info about CUCV axles by models, do you think are correct ?
M1009
10 bolt axles front and rear with 3.08 gears and a Gov-Loc in the rear (Not Dana 60 front and 14 bolt rear like some believe)
All other CUCV’s
Dana 60 front
Front Capacity 4.5 Quarts
14 Bolt FF rear with Detroit locker and 4.56 gears (some have a true-track locker in the front as well, but it is rare)
Rear Capacity 5.4 Quarts
M1028 needs GM additive
Old 04-30-2016, 08:30 AM   #23
hatzie
Moderator
hatzie's Avatar
M1009
All other CUCV’s
Dana 60 front
The M1009 is the K series Blazer with 10 bolt axles.
Axle capacity is in PINTS not quarts...
The M1028A2 and A3 should have the transfer case of the vehicle it was converted from. M1028 dually conversions should still have the NP208 transfer case M1031 dually conversions should have the NP205.
The CUCV WIKI on the Steel Soldiers forum. http://www.steelsoldiers.com/showthr...7427-Cucv-Wiki
Old 04-30-2016, 09:11 AM   #24
Redneck79
Redneck79's Avatar
So I have to avoid the M1009 because it have not Detroit Locker in rear axle, Dana in the font and not 4.56
Old 04-30-2016, 10:37 AM   #25
Greenlee
Greenlee's Avatar
M1009 is the CUCV version of a k5 Blazer. The truck you are looking at buying in the pictures above appears to be a M1008.
Greenlee is offline   Reply With Quote
