Old 04-24-2016, 11:27 AM   #1
68350
68350's Avatar
Fuel tank resto
Anyone had a fuel tank fixed and restored? My factory auxiliary tank in my 72 is leaking out of the corner so I will need your remove it and get it fixed. I was hoping I could get it coated in something too after it is fixed, rhino lining maybe? Thanks for any help
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 04-24-2016, 02:35 PM   #2
geunther
geunther's Avatar
Re: Fuel tank resto
Lining the inside or outside? The reason I ask, when ever I do work on a fuel tank, I make sure it will hold water. Even then, fuel can leak when a tank will hold water. So, I then use red-kite to line the inside of the tank.
If you mean the outside (which I assume you did), I think rhino or similar would do the trick.
geunther is offline   Reply With Quote
Old 04-24-2016, 05:25 PM   #3
Gromit
Re: Fuel tank resto
This is just a suggestion but you might consider the replacements that are readily available new. For example LMC's version is only $150..
Maybe Summit has one too..
Gromit is offline   Reply With Quote
Old 04-24-2016, 10:57 PM   #4
68350
68350's Avatar
Re: Fuel tank resto
I wasnt aware anyone reproduced the auxiliary tank. I will look into it. And I guess I was talking about both inside and out. Rhino for out and I wasn't sure on inside. Thanks for suggestion
Old 04-24-2016, 11:18 PM   #5
Gromit
Re: Fuel tank resto
Sorry! I missed that word "auxiliary" in your original post.. I thought you meant the in-cab tank...
Pretty sure no one is producing the aux tanks - at least the saddle style but maybe there could be a modern RV tank that would fit..
So you were on the right track with restoring yours..
