#176 |
The Older Generation
Re: What did you do to your Suburban Today?
I installed the Dakota Digital Speedometer converter box so I can use my stock speedometer with the 4l60e. Works like a champ & easy to set up. I also had the muffler shop install "J" pipes on my tail pipes to get rid of the nasty drone and hollow sound of the Flowmaster knock off mufflers I had them put on it. They work like a champ too!!! Put about 150 miles on it today and I could actually hear the music playing..... I'm a happy camper! LockDoc
#177 |
Sold it!
#178 |
![]() Join Date: Jul 2010
Had to research the "J-Tube." AKA Helmholtz tubes. Very interesting idea. Might do the same.
How did the exhaust shop decide what length to use?
JB from AZ 1969 Chevy Sub K10 1957 Chevy 3200 1962 VW Beetle 1957 Willys CJ5 ![]() |
#179 | |
It is a set length depending on your driving habits and RPM of the drone. Mine needed to be 28.25 inches long overall. There are charts in some of the writeups. I will see if I can find one.... If I do I will edit this post and add it. Edit: Here is the chart. All I did was drive the speed I most often drive, note the RPM at that speed and check the pipe length at that RPM on the chart. I don't drive interstates much so I just set it for the RPM at 60mph and it seems to work pretty good for all speeds. If a person is concerned about multiple speeds the second picture shows an adjustable pipe. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 04-27-2016 at 11:59 AM. |
#180 |
Not nearly exciting as a new paint job, or a new metal floor, but just a little addition to the back end to keep some tools and cleaning stuff in order. A set of vintage luggage for The Burb.
Bob 1967 2wd Burb, 350/TH350, 3.73 posi |
#181 | |
![]() Join Date: Feb 2016
![]() Quote:
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#182 |
![]() Join Date: Mar 2013
Can they be installed anywhere along the run to be effective? Any pictures of your installation ?
Thanks |
#183 | |
I'm diggin' the suitcases. I have a couple of older ones that were my moms. Nice touch.... LockDoc
#184 | |
LockDoc
#185 | |
![]() http://ls1tech.com/forums/conversion...ps-solved.html
#186 |
![]() Join Date: Oct 2004
Had my local muffler shop install a duel exhaust. It goes over the Trans cross member and through the center cross member. The mufflers are right after the center cross member and are Flowmaster supper 44's. It then curves around the rear coil springs and exits at the rear. I also had a O2 sensor bung welded on for a future EFI sensor. I included two pics of the exhaust, one showing it going through the center cross member and the other showing it going around the rear coil spring. The sound is way better than the PO's exhaust that was on it.
I also replaced the driver and front passenger window regulators and all the window seals.
Steven 69 Chevy C10 Suburban 350 700R4 w/Disc brakes on all four corners ![]() 2017 50th Anniversary Camaro SS 2004 Chevy Impala LS 2016 Chevy Malibu LT |
#187 |
Re: Rear Floor installed and Lizard Skinned
do you have 3 point seat belts on the pass side of the 2nd row seat? I have been thinking about adding some but thought it might be strange to mount it.
----------------------------------------------------------- Erik My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626 1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647 RUST!? Thats just mother natures way of telling all of us.....MINE!!!! |
#188 |
![]() Join Date: Sep 2013
I came to that same realization on that belt too, would be awkward for the person in that seat and for the people getting past it to the rear seat. I opted for a lap belt for that one and also in the center of the front bench too just in case I needed to pack 7 people in.
#189 |
![]() Join Date: Dec 2009
When I bought my '70 k10 last summer, I had to replace a bent pushrod before I drove it home. As 350's are famous for, the rocker arm stud was pulling out. So, today, I pulled the intake and heads off. Water has been mixing in with the oil, so I am going to rebuild it. Haven't pulled the pan yet, but I have a 350 4 bolt standard block that I will use for my '70! How rare is it to have a 350 4 bolt that's standard!
1977 Chevrolet K10 SWB Project 350/4spd/np205 1977 Chevrolet K20 LWB 350/350/203 1991 4Runner 22RE 5 SPD Yanmar Tractor 3 Cyl Diesel |
#190 | |
#191 |
#192 | |
#193 |
I made a AC cooling plenum. Apparently the air from the fans was passing thru the radiator but bypassing the condenser. I need to fill in the lower side too.
#194 |
Strongman Garage
![]() Join Date: Apr 2000
Picked up a Dana 44 front with discs and some 4x4 rally rollers
Kalle 68 GMC Suburban 1500 4x4 SOLD 69 Pontiac Lemans 99 Silverado 4.8 5 speed ECSB [ Facebook Instagram Subscribe on YOUTUBE |
#195 |
#196 |
I installed a fuel gauge and regulator that fixed an issue I had been chasing since I bought the Burb, engine shake that would show its ugly face at about 1,500 rpm in park / neutral and above 50 mph turns out the carb was being flooded... Idle was always fine .... Happy camper right over here
#197 |
I replaced my heads this weekend
![]() Over the couple years I've had it, the amount of oil consumption had increased a good amount up to about a quart per tank. It smoked on start up, idle, acceleration...yada yada. It has been very nice NOT to see anything billowing out since. What a chore though, it took two of us about 12 hours, but a third of that was trying to remount the AC compressor! |
#198 | |
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
#199 | |
specs are available there too. I think all specs are the same as my stock heads except the larger intake valve. I still fighting retuning, but I have to think it's running smoother across all rpms, but nothing dramatic. It quit smoking cold turkey which was the main objective. |
#200 | |
