04-24-2016, 11:22 PM | #1 |
Vacuum pod on back of 59 dash, Speedo
There is a vacuum device on the back of my dash. The speedo cable screws into this which is screwed into the dash itself. There is about 10" of vacuum hose hooked up. I have no idea where this vacuum line goes.
I am sure someone here knows |
04-25-2016, 01:07 AM | #2 |
Re: Vacuum pod on back of 59 dash, Speedo
is there any other linkage etc attached or just a vacuum pod? post a pic so we can see what you have there. what year/model of truck? was it a commercial unit or farm unit at some point-like maybe some sort of governor attachment or high idle throttle control for a pto, cruise control? is there linkage to throttle linkage? is there an output for the speedo cable as well or just an input?
04-25-2016, 10:54 AM | #3 |
Hollister Road Co.
The vacuum pods were off of a truck with a two speed rear end. That pod has some gears in it that switches the speedo so it matches the actual road speed when splitting shifts. Over on www.stovebolt.com they can tell you more about it. Its a rather hard to find item
04-25-2016, 11:52 AM | #4 | |
Thats exctly what is for.... dwcsr is right the line goes to the switch located on the shift knob a button if you will when you shift the two speed rear end from lo/hi vacuum is supplied from the tank through the "Switch" to the vacuum diaphragm on the rear also to that gizmo on the back of the speedo to match road speeds . look in big bolt( stoveboltforum) or here in Heavy Haulers (67-72chevytruck) if you need more info......Sp . . .
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
04-25-2016, 11:53 AM | #5 |
I am just asking here, would it have anything to do with vacuum wipers?
Allen Never mind as i think this was posted the same time as the above post! |
04-25-2016, 07:14 PM | #6 |
davis posted previously that he has a 59 bus
my 56 bus had the 2 speed rearend and the speedo to match with the vacuum actuator to shift the speedo like softpatch posted
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
