Old 04-25-2016, 11:46 PM   #1
BigFrz
My 51 GMC Build
This is my first build. It's a 51 GMC on a S10 frame swap with air ride going with 6.0L. Plz give me any advice. Thanks
BigFrz is offline   Reply With Quote
Old 04-26-2016, 11:55 PM   #2
DeanTX
DeanTX's Avatar
Re: My 51 GMC Build
Nice looking truck. Looks like you have a good stock of wheels too!
DeanTX is offline   Reply With Quote
Old 05-01-2016, 01:58 PM   #3
BigFrz
Re: My 51 GMC Build
We went to install the 6.0 in it. Using Dirty Dingo motor mounts. Sat the motor on the mounts. Back of the heads was like 6 inch from the firewall. So we are thinking that we would have to make a bracket and set mounts on new bracket to push the motor back. Any ideas.
Old 05-01-2016, 02:23 PM   #4
joedoh
joedoh's Avatar
Re: My 51 GMC Build
if its in an s10 frame you need the motor moved back 5-6 inches, or the clutch fan will look like a propeller out the front of the truck (not really)
if your mounts are the typical s10 mounts that move the engine forward, try swapping them side to side so they actually move the motor back. the amount of move should be 4.5" coupled with the extra cylinder should be just about perfect.
Old 05-01-2016, 04:32 PM   #5
BigFrz
Re: My 51 GMC Build
Joe doh thanks alot. Will do and if need will post pics of new brackets if the other way don't work thanks
