#201 |
Re: tjs 72 Blazer Build
If you push yourself, you may be able to have it ready for this year's Syracuse Nats ! ;-)
Looks awesome BTW !! |
#202 |
A guy with a truck
Beautiful, just wow.
What size tires are you planning for her?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#203 |
Thanks Dan. Maybe wishful thinking !! I don't have an exact timetable yet.
The good thing that it is painted now is that the Body shop is motivated to get their stuff completed. The longer it is in their shop the more chance it could get damaged and until all the panels are back on the Chassis it is taking up more than one bay. I need to balance my vacation time between truck and family stuff so we shall see how it goes. I have very little play time for the truck when I am working. If I could get one full week on it with a helper I think I could knock a lot out. The most time consuming thing when I get it back will be all the wiring. I'm comfortable doing that type of work myself but I'm using an AAW update series which means everything needs to be routed, terminated and loomed. Very similar to what you went through without the LS motor.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 Last edited by tjsblazer; 04-26-2016 at 04:50 PM. |
#204 | |
I'm thinking 295 / 75 R16 which spec is 33.3" tall x 11.6" wide but I need to get the body all back on the Chassis and get my pinion angle squared away if required and see how everything is sitting first. With the custom springs it isn't like buying off the shelf where they run hundreds of them and know exactly how it will sit. The goal was to be approximately 2" higher than stock.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
#205 |
Things will come along nice once body is on the frame. Then its just tinker time. Once the first test drive it will fire you up to complete.
#206 |
Not sure if you guys in the GTA got the weather we got. All ice pellets last night then snow on the ground until noon. Not much of a motivator.
#207 |
Not here !! Cold as heck yesterday, but hopefully this is the end of it. Supposed to be a nice weekend. I'm planning on going to the Stirling market with the Blazer on Saturday. It will be the furthest drive with it thus far.
#208 |
Want to meet there? I will prob take the kids.
#209 |
I wish I could drive mine ...
#210 |
Got new foam and covers on the seats (from Truckseats). Sport buckets with low grade (non-scroll) covers. The rear bench is just almost all out of the Rh side of the picture but they rebuilt the factory foam and new matching cover also.
The tails aren't finished yet. That is because I have to finish up the routing of the w/h pigtails that are hanging out. That is for seat heaters. I put them in both buckets and the 2 outside positions on the rear bench. It can get a little chilly at night with the top off.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 Last edited by tjsblazer; 04-28-2016 at 04:23 PM. |
#211 |
Seats look great. Heated seats is a great idea. I also keep a bag of blankets too.
#212 |
#213 |
Nice seats !! I kinda wish my truck had those instead of the utility buckets. Mine are real comfy, but I find you sit too high in them and they rub against the console. Good idea using the heated inserts. I prefer the non-scroll seat covers also.
#214 |
Love your build. Very organized and great execution. I like the colour choice. Looking forward to seeing the finished product.
#215 |
My wife's favourite auto accessory is the heated seats so this was an easy up charge.
#216 |
Thank you. This isn't my first restoration although the others were mid-year vettes. I think making a plan and trying to stick to it is the best way to go. Also helps keep your budget honest if you are realistic with yourself up front.
#217 |
Some progress over the past few weeks.
The panel gaps and levelness came out really nice. Very respectable for a 44 year old truck. There wasn't any metal work really done and I think the body shop spent a little more time on it than the factory might have. So far I am liking how it is sitting on the custom springs. It will sit down a little bit more once a few hundred pounds of interior, spare tire, and fuel gets in it. It has a little rake towards the front but I was very clear with the top installed it had to be level and not have a saggy ass so I think it is shaping up the way I asked for. The tires look a little bit small in there but those ones measure 29". I'm still leaning towards 295/75 R16 which measure a full 33" . So far I have a big ![]()
#218 |
Some more.
#219 |
Here is a few pics trying to show the boxliner I had sprayed in both the front and rear wheel wells. I'm very happy with the texture. It is fairly smooth compared to some which makes it easier to keep clean but it will still be resilient to stone chips.
#220 |
I'm trying....
![]() Join Date: Oct 2013
Another crisp arctic build. You guys do it clean and precise. This is a project that is very satisfying to watch. Is it the metric system that makes you so exacting or is it your elocution that makes everything so darned oot-standing--aye? Can't wait for more.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
#221 |
A guy with a truck
So nice. Keep the pics comin'.
#222 |
WOW! Nice work man!
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 ![]() |
#223 |
![]() Join Date: Oct 2011
i was going to ask something or other about your Alcan springs. then i read the whole build all the way through....
now my CRS is kicking in and i can't remember what i was going to ask. keep up the excellent work! it looks fantastic!
Dave "... government even in its best state is but a necessary evil. Thomas Paine "It wasn't a lie, it was ineptitude with insufficient cover." Donald Draper (Mad Men) |
#224 |
Looking great! All this shinny new paint so close to home makes me a little itchy to fresh'n up mine.
#225 | ||
