Old 04-29-2016, 03:23 PM   #1
class01
class01's Avatar
wheel backspace
I know this topic comes up a lot.I have 20x8.5s 5.25BS and 20x10s 5.5BS on my truck now. im bagging the truck and putting in a bolt-in C-notch. Is my backspace good for a bagged track? 72 rearend
class01 is offline   Reply With Quote
Old 04-29-2016, 03:29 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: wheel backspace
Sure.
But you have the answer right in front of you.
Remove the springs and lay the truck out.
You will need an adjustable track bar to re-center the rearend.
Seems like you could tell us if this will work, instead of the other way around.
Use quality shocks and rear shock relocators also.
Trim any bumpstops or brackets that are in the way.
Keith
Convert to disc brakes.
Old 04-29-2016, 03:39 PM   #3
class01
class01's Avatar
Re: wheel backspace
Sure.
Only thing is I have the bed and the wheels off right now to install the airbag kit. I kinda wanted to get some new wheels before the price goes up next month. but I guess I could measure..........
Old 04-30-2016, 03:27 AM   #4
andrewmp6
Re: wheel backspace
For 80 bucks you can buy a percys wheelrite that will let you test out any rim size and backspacing you can think of.
Old 04-30-2016, 01:30 PM   #5
Pro Performance
Pro Performance's Avatar
Re: wheel backspace
You should be all good to go. Let us know if we can help with the new set.
Travis
Pro Performance is offline   Reply With Quote
Old 05-01-2016, 01:01 AM   #6
BossHogg69
motor exploder
BossHogg69's Avatar
Re: wheel backspace
Sure.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
