05-01-2016, 11:40 AM | #3626 |
Re: What did you do to your truck today? Chapter II
So far spent most of the morning tracking down a rattle in the drive train. No luck so I'll keep looking as I watch the race!
05-01-2016, 11:55 AM | #3627 |
05-01-2016, 10:52 PM | #3628 |
If someone would have told me it would 5 days to cut, dado, router, drill, mock up install, reinstall, reinstall then get my custom 68' short wood bed on the frame ( after lifting it off to drill the gas filler hole) i'd say they were crazy. not anymore..
05-01-2016, 11:20 PM | #3629 |
Well by the looks of it perfection takes a few days, sure looks good.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
05-01-2016, 11:37 PM | #3630 |
Nice Sunday spent in the driveway.
New starter hooked up on my Dad's C-10. Shocks, front and rear greased on my C-20.
Chris '69 C-20 '04 Jeep TJ |
05-01-2016, 11:42 PM | #3631 |
Sure looks good though.
05-02-2016, 11:17 AM | #3632 |
Last night - cleaned out my buddy's garage (moved his jeep out, and equipment) got the C10 on the lift and took wheels off to start replacing brake cylinders, he's going to work on that this week while he is "slow" on other work, hopefully have the exhaust put in this week!
Got my insurance on it this morning and getting ready to head to DMV to get tags - woohoo! here's some pics of the original bed and tailgate, then the replacement I found for $200! I didn't realize it had an original wood bed - the plate steel has always been in it as long as I can remember, when we lifted it up to do the brakes, some of the wood fell down, it's almost like one of those house shows where they pull the carpet up and "hey you have wood floors!" - only problem here is that I can't simply remove the covering and be done! My friend said something to me a few weeks ago about how my grandpa put that in, because there was some ply-wood under the steel that was rotted, upon closer inspection last night we realized it wasn't plywood but the original wood floor. |
05-02-2016, 12:05 PM | #3633 |
working on an Electric Vacuum Pump install on mine for a solution to the low vacuum due to my "Lumpy" cam.......tested it at work and got 25" of Vacuum...it's off a 2003 Audi A4, some Volkswagen cars had them too....cost me $26.00 at Pick n Pull.
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time" “Serious Black” my 1971 Short Bed Fleetside Sold to an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten” |
05-02-2016, 12:49 PM | #3634 |
Boosted Member
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
05-02-2016, 01:21 PM | #3635 |
72 GMC
Front springs and shocks. Seperating the
ball joints from the spindles was NOT easy ! But, its done !
KEL Members I have met : 2014.02.01: bruceman1968, Mr Handy, colgad, RenoKeene, CaptRMW |
05-02-2016, 01:25 PM | #3636 |
05-02-2016, 01:30 PM | #3637 |
Boosted Member
Yea it's pretty loud. I'm gonna make some baffles to slip inside. I drove it around for quite awhile with a very similar setup back when I first got it running.
05-02-2016, 01:44 PM | #3638 |
oh hell yes!
05-02-2016, 07:53 PM | #3639 |
lol.. I bet it cuts down on the over spray doing it upside down on the ceiling though
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
05-04-2016, 11:55 AM | #3640 |
Just about to finish new water pump install...waiting on new pepcock, put on upper hose and add 50/50.
1970 C10 Short Stepper with 71/72 front clip. |
05-05-2016, 09:50 AM | #3641 | |
Thanks guys it was my first bed job. worked out pretty well using off the shelf composite decking material. spacing is bigger between boards but the strips lined up factory once I used the larger center board in place of the factory style skinny center boards. I eliminated the offset top washers and am using allen-button head SS bolts instead. |
05-05-2016, 05:27 PM | #3642 |
Got the grill guard installed--bought it from a fellow member here. Okay, I drilled two holes--have left the outboard ones for now.... Thanks Al, great meeting you and thanks for your patience! Dave
05-05-2016, 06:36 PM | #3643 | |
With the '72's plastic grill, I have decided to sport a grill guard once she's mobile. |
05-06-2016, 09:15 AM | #3644 |
I didn't do anything to it (yesterday) except pay the paint/body warden for his work to date..
05-06-2016, 09:16 AM | #3645 |
05-06-2016, 10:21 AM | #3646 |
I just really dug the look of the early guards. It's probably the only thing non-original on the truck at this point but it was worth a couple of extra holes in the bumper!
05-06-2016, 10:34 AM | #3647 |
I feel your pain
05-06-2016, 12:25 PM | #3648 |
Gots wood, doing some ripping today......
1967 C10 SWB Owner - Rustbelt Restorations |
05-07-2016, 12:23 AM | #3649 |
70+ ( Old Skool Club )
What did I did to my truck today? Well its like what have I been doing all week. Did some under hood detailing and it was easy with the hood off. Installed my LED plug and play tail lights I bought from Wes at Classic Heartbeat last summer. Realized while poking under the hood my A/C clutch needs replacing
http://67-72chevytrucks.com/vboard/s...d.php?t=706266 Changed my upper tailgate mouldings myself and learned they only go on one way, yes there is a top and bottom to them. I knew the left front fender on the truck had been damaged and discovered it was replaced with used one, but I don't think one from a 72. I'll stop now , but let me say its been a great week and I learned some things about my truck and that I can do things I thought I couldn't.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
05-07-2016, 01:06 AM | #3650 |
Lit up the tires in public!
