Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 03-21-2016, 01:32 AM   #1
ETraugott
"The wifes truck" 1994 K1500
My wife still has her first truck and honesly dont even think she would sell it for anything. She bought the truck from a family friend on payments. Its a 94 K1500 with a 4.3 V6 and 4l60E. The truck as of now has 278,000 miles and we were using it as a back up vehicle till it blew a heater hose. The motor was tired, leaked oil so i didnt even waste any time fixing the 4.3. It prob sat for 8 months and is now in its current situation. I decieded to go ahead and do a 5.3 swap. I got a complete 5.3 from a junkyard and found a 4l60E and transfercase out of a 2002 truck. I plan to keep slowly fixing the truck up so figurd i should start a thread to show the progression.
As of today i have the engine and trans in. The only real clearence issues i have is the a/c compressor. Holley makes a relocating bracket that i will be using. I am using the stock harness that I cleaned up. I used most all info and had computer programmed by brendan at lt1swaps.com. I am using the factory cats and y pipe from the donor truck. This truck wiil have to pass the "sniffer" test for emmissions so I left the cats on.
52 Chevy 6400, 1 ton dually 4x4 350 vortec NV4500 315/75-16 tires
http://67-72chevytrucks.com/vboard/s...d.php?t=661795
94 Chevy K1500 4.3 4l60e (The Wifes)
ETraugott is offline   Reply With Quote
Old 03-21-2016, 01:35 AM   #2
ETraugott
Re: "The wifes truck" 1994 K1500
2000 truck 5.3 donor engine.
Old 03-21-2016, 01:37 AM   #3
ETraugott
Tearing down to clean up and reseal.
Old 03-21-2016, 01:39 AM   #4
ETraugott
Cleaned up
Old 03-21-2016, 01:41 AM   #5
ETraugott
Old 4.3
Old 03-21-2016, 01:43 AM   #6
ETraugott
Empty
Old 03-21-2016, 01:45 AM   #7
ETraugott
Cleaning up the truck harness.
Old 03-21-2016, 01:48 AM   #8
ETraugott
In the hole
Old 03-21-2016, 01:52 AM   #9
ETraugott
Built a bracket to mount ECU in location of old air intake. I also moved the battery to the driver side and plan to run the factory air box fom the donor truck which will have to sit where battery is.
Old 03-21-2016, 01:53 AM   #10
ETraugott
Mocking everything up.
Old 03-21-2016, 01:55 AM   #11
ETraugott
Still need a/c bracket to verify clearence. Had to modify air intake also.
Old 03-21-2016, 01:57 AM   #12
ETraugott
Mock up.
Old 03-21-2016, 02:06 PM   #13
ETraugott
Here is a pic from a few years back when it was cleaned up. Sorry for the blurry pic.
Old 03-21-2016, 05:10 PM   #14
OutlawDrifter
looks like you'll have a great driver
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 03-22-2016, 06:51 AM   #15
Bout ready for another 270K-ish miles!
Old 03-22-2016, 01:37 PM   #16
ETraugott
Holley relocating bracket and spacing kit. I got it installed last night. There is some clearnce issues if trying to use the stock intake piping fron filter box to intake manifold. There is a piece that hangs off the bottom. I cut it off and plugged the round hole. Also had to heat a small area on top with heat gun and push it down. The other alternitive is i know the spectre cold air kit off of a 2000 will work with no issues also. My buddies truck has one and i test fit it so it will also work. The low pressure line is a little to short, my solution is to cut the aluminum tube at compressor fitting and reweld for a better angle. I slso got the shift linkage hooked up last night. Had to modify it also for clearence because newer trans had the black box on side. Hopully tonight i will get the fuel lines connected and the intake bolted down for good.
Old 03-22-2016, 01:40 PM   #17
ETraugott
Compressor installed. Belt length is around 108.5 inches. Will post part # when i find the best fit.
Old 05-01-2016, 11:38 PM   #18
ETraugott
Its been a while since my last post. Truck is running and driving. Put a thrush muffler on it. Has a nice tone. Wife loves the sound. Still have a little wiring to finish up. I also changed the rear leaf springs from a light 3/4 ton, (6lug). May eventually put the 14 blot in it. The center caps were rusty. I came aross some stock center caps for free. Had to modify them on a belt sander to make them work but like the look. Today i swapped grill and put a less bent up bumper on it i had. Got a cheap ebay light kit. Looks good but lacks in quality.
Old 05-01-2016, 11:40 PM   #19
ETraugott
Thrush muffler
Old 05-01-2016, 11:43 PM   #20
ETraugott
Factory center caps with mickey thompson wheels
Old 05-01-2016, 11:47 PM   #21
ETraugott
Before... Grille and bumper
Old 05-01-2016, 11:48 PM   #22
ETraugott
After... Still need some cleaning on the grille and bumper but happy with the looks.
Old 05-01-2016, 11:56 PM   #23
ETraugott
Oh yeah the leaf spring swap. I changed them for a couple reasons. The truck has a lean or sag to the left and she will be using to pull her small aluminum horse trailer. Well the leaf springs didnt fix the lean. Maybe a soft or weak tortion bar?
Old 05-02-2016, 11:50 AM   #24
rs74
rs74's Avatar
Have you read anything about using the TBI style AC bracket on the 5.3? I am going to look into this for mine since I am not going to notch the frame for it. I need to look into engine mounts too.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 05-02-2016, 12:34 PM   #25
ETraugott
Havent seen that one. I used the holley bracket. Little pricey but works great.
