Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 05-03-2016, 12:12 AM   #1
Skull Bucket
Big Block Swap For Trailer Towing
Thinking about putting a big block in place of the 283 in my 1966 Suburban. Been towing a 27 foot dbl axle camper trailer and feeling the limitations of the 283 small block - "it's time to put a bigger motor".
Looking for comments regarding ease of fitment, references to example threads that may be out there, suggested motor/auto-tranny combo.
Not looking for the Corvette super motor, just a good old fashioned big block with carburetor.
Skull Bucket is offline   Reply With Quote
Old 05-03-2016, 02:06 AM   #2
RockTonka
RockTonka's Avatar
Re: Big Block Swap For Trailer Towing
Pretty much what we did...BBC/T400/D60.
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 05-03-2016, 09:59 AM   #3
Skull Bucket
Thanks I have started looking at your awesome thread. Haven't studied every detail that you shared yet....did the motor fit in easy or was there clearance issues???
Old 05-21-2016, 03:57 AM   #4
MikeS.
MikeS.'s Avatar
You will probably need to modify the firewall to get a big block to fit in there. One day I'm going to put up 350 in mine. Pretty much A drop in motor swap.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 05-22-2016, 01:11 AM   #5
Captainfab
60-66 Nut
You do not have to modify the firewall. You just need to move the engine forward with either the '68-'71 big block engine mounts and brackets, or the '73-'87 engine mounts. The '73-'87 frame brackets from a C20/30 fit the earlier frames better than the C10 brackets.
I did not modify the firewall on my '66 Suburban, but I did fabricate some custom engine mount brackets that moved the engine forward about 2" from the original location.
Old 06-29-2016, 04:43 PM   #6
Harley Truck
Big block fits no problem either way as long as you use factory valve covers. Larger aftermarket chrome or aluminum covers will need more clearance. I am running 454/700r4 combo.
Harley Truck is offline   Reply With Quote
