Old 05-03-2016, 12:14 AM   #76
Captainfab
60-66 Nut
Re: 1966 and later park brake system - layout with photos - no cross member
I was able to get under there and get a measurement today. From the same starting point as in my pic above the hole is at 3.5"
Old 05-03-2016, 09:10 AM   #77
62chevy302
hillbilly
62chevy302's Avatar
Awesome thanks
-1962 C-10
62chevy302 is offline   Reply With Quote
Old 05-11-2016, 06:44 PM   #78
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I might have missed it if it was posted because I'm mobile, but I'm going to do this upgrade and I want to use this system for the 69-72 where they went to the floor pedal instead of a handle.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 07-20-2016, 09:43 PM   #79
MD67C10
I kind of like the handle on my 67 but often thought it would be nice to have a few gauges mounted in that location.
MD67C10 is offline   Reply With Quote
Old 02-15-2017, 06:35 PM   #80
AnobleL74
Originally Posted by Woogeroo View Post
1965 Chevrolet C10.
pull/release brake handle under the dash/steering column.
Attachment 1030832
This photo the cable going through the floor of the cab, underneath the steering column.
Attachment 1030852
The bottom two photos shows the cable where it attaches to the brake handle lock mechanism under the dash/steering column.
I hope this helps.
If any of you other folks have photos of your 1966-1972 style park brake systems, feel free to add them in here. That way the folks who are pondering doing this swap will have a better idea of what parts they need and how it all goes together.
FYI: this isn't a plug for their parts, but the LMC Truck 60-66 catalog has a pretty good list/exploded view of the parts for this brake system in their catalog. You can check it out on their website.
Many other vendors sell some of the bits and pieces, so check around and do some research.
As always, check the Review Board here on the forum before buying any parts from anywhere.
-W
p.s. some of you may notice the bolt with the nut sitting by the cable. I think the bracket was an aftermarket part. I do not recall if the bracket was for the '65 c10 or the later truck... however, when I got it all set up, the cable sheathing itself would not stay secure in place, therefore nothing worked. You can see where the coating is torn from this movement.
This was my good ol' boy solution. I used a bolt as a spacer to snug things up.
a fellow old truck pal(64fleetside on the stovebolt page) had this to share : I've had a couple slip too, woog-I've usually removed the clamp and smacked it w/a hammer, then it fit tighter.
p.s. update/edit 01/03/2013 - a link to a thread here on the forum with up close shot of the original park brake mechanism for 60-65
Can any one help me id and find the top cable clamp used to secure the cable so you can actuate the cable/brake. there is a pic in this post, but i can not find this clamp anywhere. my truck is a 66 but the calm is missing. thanks Allan
AnobleL74 is offline   Reply With Quote
