Old 05-03-2016, 08:24 AM   #1
77c10
77c10's Avatar
4L80E torque converter
I've got a new converter for my 6.0/4L80E swap. It is stock and measures about 13". everything I'm reading says it should hold 5 quarts of fluid. I've been filling it since Saturday night and I have only able to get 4 quarts in it so far. I'm thinking that should be good enough for now. Looking for thoughts from others...
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint
"Cool ain't ever cheap and cheap ain't ever cool"
77c10 is offline   Reply With Quote
Old 05-03-2016, 09:22 AM   #2
homemade87
Re: 4L80E torque converter
Thats plenty for a start up . You will never get it full just pouring in fluid . Fill the pan and start it up and let it run just enough for the pump to fill the rest of the system and shut it off and recheck and fill . After a full heat cycle check it again .
homemade87 is offline   Reply With Quote
Old 05-03-2016, 10:01 AM   #3
mongocanfly
mongocanfly's Avatar
If its a completely dry system its going to hold a lot more than 5 qts..did you fill the t/c ? It holds about a qt by itself..we just swapped a 4l60 out, flushed complete system,blew out all lines and trans cooler, and I think it held a total of around 12 qts..I may be off a little on amount...clinebarger would know for sure..
Old 05-03-2016, 11:41 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I dump a few qts into the convertor itself before installing, then fill the trans. Until the thing is spinning and pumping fluid, it'll never fill entirely. Between the convertor, trans, and my cooler, it was like 13ish qts
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-03-2016, 01:39 PM   #5
77c10
77c10's Avatar
Sorry, I didn't clarify. I'm filling the converter on my work bench before I install it on the trans and bolt the engine and trans together.
Old 05-03-2016, 08:25 PM   #6
clinebarger
I have never pre filled a Converter in my life, The Pump will Charge the Converter instantly upon start-up.
clinebarger is offline   Reply With Quote
Old 05-03-2016, 09:41 PM   #7
mongocanfly
Clinebarger..Ive never heard of anyone doing it that way before..I dont do it for a living but I've always poured at least a quart in them before install...learn something new ever day..good to know..
Old 05-16-2016, 04:54 PM   #8
TooTall
Its 13 total . . . .
The less that you have in the converter before it gets installed, the better off you are not to gouge any orings
1984 K10, 8" lift on 35s
2011 Yukon XL | Bone stock
2013 Audi Q5
