Old 05-04-2016, 07:00 AM   #1
Diesel3+3
Heavy duty crew cab rocker panels?
I've got an 87 Crew cab which needs rockers. Living in the north east and concerned about rust. Who makes crew cab rockers in the thickest gauge material? Thanks
Diesel3+3 is offline   Reply With Quote
Old 05-04-2016, 12:29 PM   #2
daddyjeep
daddyjeep's Avatar
Re: Heavy duty crew cab rocker panels?
for a complete rocker...nobody makes them from what I could find. You can get slip on rockers for the crew cab, but they do not extend into the door sill. I bought 2 sets of regular cab rockers and modified them to fit the rear door.
[IMG][/IMG]
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 05-04-2016, 01:55 PM   #3
Diesel3+3
Where did you get them from. We're they equivalent to that of the factory sheet metal?
Old 05-04-2016, 02:07 PM   #4
daddyjeep
daddyjeep's Avatar
I got them from a local auto body Supply place to avoid the shipping cost from LMC or Brothers. I didn't measure the thickness, but it is very similar to factory material.
04 1500 crew cab
Old 05-05-2016, 11:26 PM   #5
barry1982
I just did the inner/ outer rockers, and inner/outer cab corners on my 82 regular cab. Try find a distributor for "Key Parts" . I was surprised how heavy the panels were, and believe they are as thick, or slightly thicker than original equipment.
barry1982 is offline   Reply With Quote
Old 05-06-2016, 02:03 AM   #6
andrewmp6
Use weld through primer on the inside of the rockers and under coating on the back side once you get them welded in.
