05-05-2016, 03:05 PM | #201 |
Re: Plus Five
I installed the inner fenders and some components.
53 Chevy Pickup |
05-05-2016, 03:13 PM | #202 |
Re: Plus Five
I installed the radiator reservoir. I built this from .060 aluminum.
The cap is from a nissan reservoir. I copied the thread profile and cut the threads on the lathe, then welded the neck to the top flange before welding up the rest of the tank. The over flow refills into the bottom of the reservoir, and any more than that will go out the reservoir overflow at the top of the tank, then down to the ground.
53 Chevy Pickup |
05-05-2016, 03:17 PM | #203 |
Re: Plus Five
The big square hole on the passenger side inner fender is for the
air intake. I'll post that soon.
53 Chevy Pickup |
05-07-2016, 05:19 PM | #204 |
Re: Plus Five
I reinstalled the front end tilt frame and greased up the pivots and the sway bar links and pivots.
53 Chevy Pickup |
05-07-2016, 05:30 PM | #205 |
Re: Plus Five
half round rubber pads for the stop,
front pivot bushings...
53 Chevy Pickup |
05-07-2016, 05:35 PM | #206 |
Re: Plus Five
just enough clearance...
53 Chevy Pickup |
05-07-2016, 09:22 PM | #207 |
Re: Plus Five
Very nice...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
05-09-2016, 10:27 AM | #208 |
Re: Plus Five
I love everything about your build. Your attention to detail, and willingness to modify and/or fabricate parts is what I think hot rodding is all about.
I have a question about your windshield wiper setup. In Post 142 it appears that you used Ford Escort splined shafts and transmission arms for your starting point, is that correct? Also, in Post 143 are those wiper arms from a Ford Escort also? I have a 1966 GTO that my college son and I restomodded using a 6.0 LS type engine and six speed manual transmission (it is in the link below ). We have driven the car over 30,000 miles and now it is time for some upgrades. I used the same wipe motor you used, and with some work, it works great. The wiper transmission arms and "old style" wiper transmissions are noisy and have a fair amount of slop and need to be upgraded. I was considering using parts from a newer S-10, but your setup looks to be perfect for my GTO. Thanks in advance for your help. Ricky
Rick's 55 TF/Fleetside/LSx build 1958 Corvette LS1/T56 Build 1966 GTO LQ9/T56 Restomod |
05-09-2016, 08:23 PM | #209 | |
Re: Plus Five
I really enjoy making parts. As for the wiper setup, I'll have to check my notebook when I get back home. I'm out of town for the rest of the week. I think the splined arms that hold the wipers are from the rear of a couple Ford escort hatchbacks. The splined shafts had to be turned down on the lathe to fit inside the original cowl bushings. The rest of it, transmission, arms with the sockets, mounts and linkages have all been modified or made from scratch. I'll try to find more info later in the week. Don
53 Chevy Pickup |
05-13-2016, 09:29 AM | #210 |
Re: Plus Five
That flipfront is just a piece of art!!
Realy nice!!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
05-13-2016, 09:09 PM | #211 |
Re: Plus Five
Thanks,
I think it will look a little better when I get the fenders and hood back on and it's working. I'm going to try to make a video of that later, if I can get my son to help me. I've been on the road for the last five days, but I have some time off now so I should get a little done.
53 Chevy Pickup |
05-17-2016, 07:27 PM | #212 |
Re: Plus Five
Messing with a lot of little things.
The corner windows are in. The ones I had were cloudy around the edges, so I bought new ones from Classic parts. I had the glass guy put them in. He was impressed with the quality! Only charged me $20 per window. Money well spent. All glass is in now.
53 Chevy Pickup |
05-17-2016, 07:39 PM | #213 |
Re: Plus Five
Also finished up a fresh air line on the intake I made.
I made up a line from the passenger side valve cover to the air intake. I made a threaded bung and welded it to the intake pipe, and made a bracket to brace the tube. Just need a short piece of rubber hose to finish it up. I'll be finishing the power steering cooler and transmission cooler lines next.
53 Chevy Pickup |
05-18-2016, 12:27 AM | #214 |
Re: Plus Five
Just curious but what's the fresh air line on the intake tube for?
05-18-2016, 06:48 AM | #215 | |
Re: Plus Five
air to replace it comes from the filtered air. Instructions say it needs to be between the mass air flow sensor and the throttle opening for correct engine performance.
53 Chevy Pickup |
05-18-2016, 08:19 AM | #216 |
Re: Plus Five
Can you say P C V inlet!!
05-18-2016, 06:32 PM | #217 |
Re: Plus Five
I could....
but I'll stick with what the experts that built it call it. This is copied from my instructions. This port should be connected to filtered clean air. This connection must be within the engines air cleaner system and must be between the MAF (Mass Air Flow Sensor) and engine’s throttle body. The engine burns the air that enters the PCV system so, if the fresh air port is prior to the MAF then, this air will enter the engine without being measured by the MAF and adverse engine operation may occur.
53 Chevy Pickup |
05-20-2016, 09:56 PM | #218 |
Re: Plus Five
I mounted the transmission cooler and power steering
cooler. Also made up the hard lines, so just flex lines to go, then on to the electrical system.
53 Chevy Pickup |
05-20-2016, 10:01 PM | #219 |
Re: Plus Five
here's the transmission cooler,
53 Chevy Pickup |
05-21-2016, 11:53 AM | #220 |
Re: Plus Five
Well,
today I put together the braided stainless flex lines for the power steering and transmission. What a pain in the ... The instructions say to wrap black tape tight around the area to be cut, then cut thru the tape with a cut-off wheel. For the fuel lines, this worked great. For the powerflex and speed flex hose it started to unravel as soon as it was cut. The plastic coated braided stainless also swelled just enough that it wouldn't slip thru either. I fooled around with different methods, then settled on a .020 aluminum wrapped around and hose clamped. I cut the hose right next to the aluminum sleeve while the hose clamp was tight. Then I loosened it just enough to slide and gave it a quick push and it slipped thru the fitting just fine, and no unraveling. Glad that job is finished!
53 Chevy Pickup |
05-21-2016, 12:33 PM | #221 |
Re: Plus Five
Good solution. This is pretty handy. http://www.koultools.com/ANHoseAssemblyTools.html
05-21-2016, 01:17 PM | #222 | |
Re: Plus Five
Have you ever used it with teflon hoses like speedflex or powerflex ?
53 Chevy Pickup |
05-25-2016, 07:00 PM | #223 |
Re: Plus Five
I mounted a few pieces in the cab. On the passenger side is a vent and mount for the engine computer. I also painted the floor with tractor enamel to seal it all up, before mat and sound deadening go on.
Also mounted the solenoid/relay? for the tilt mechanism and the flex lines on the power steering.
53 Chevy Pickup |
05-25-2016, 07:14 PM | #224 |
Re: Plus Five
I had a little trouble with the fittings for the transmission lines. I am replacing the quick connect fittings with AN-6 adapters. I ordered the ones from Summit Racing that are used on 700R4 and various others, but the transmission threads were a little bigger diameter on my 4L65E.
I called Summit, and they checked the part # and thought it should fit. They didn't show anything else that was listed for a 4L65E. I called Pace performance, and they knew immediately which fitting I needed. The 700R4 has a 1/4 STRAIGHT pipe thread, while the newer 4L65E uses a 9/16-18 straight thread. Pace gave me the part number. I called Summit and explained all of this, and they were AWESOME!!!! They sent me the two correct fittings FREE, and no shipping charges either! So, tomorrow I'll finish those two lines also.
53 Chevy Pickup |
05-26-2016, 06:34 AM | #225 |
Re: Plus Five
FYI - Easy on the teflon on those an x male adapters. I have been told many a trans case has been cracked with to much teflon and over tightening.
Looks Great Mike |
