Old 05-05-2016, 10:32 PM   #1
sircrunch
'75 lap belt only retractor cover
I have a low mile extra nice 75 gmc. I assumed anything on my truck that is showing wear is likely something that most any truck of this age would need replaced, and would likely be easy to find in reproduction. I find that I am wrong. As soon as you open the door of my truck you are met with an eyesore. The seatbelt retractor cover is rotten plastic. This truck has the lap belt only. I was surprised to see that LMC does not appear to carry this part. Any advice?
Also has anyone ever had good fortune with attempting to "polish" the gauge lens cover? Perhaps with some headlight restore? Mine is yellowing and cloudy.
sircrunch is offline   Reply With Quote
Old 05-05-2016, 11:59 PM   #2
E.D.75GMC
E.D.75GMC's Avatar
Re: '75 lap belt only retractor cover
I wasn't able to get the cloudiness out of my gauge lens, so I purchased a new one. Can't remember if it was from LMC or Classic Industries though, and I also used model paint on the needles.
E.D.75GMC is offline   Reply With Quote
Old 05-08-2016, 03:37 PM   #3
75gmck25
My '75 also had lap belts only, but when I removed the trim panel on the door frame I found out it had the welded anchor points with bolt holes for three-point seat belts . The hole to match the anchor was also molded on the back of the plastic trim, but had not been drilled out. I found a full set of three-point belts in a junkyard truck and swapped them over to my truck.
LMC sells both lap belts and three-point belts, but they appear to be the same generic models that other suppliers have.
Bruce
75gmck25 is offline   Reply With Quote
Old 05-08-2016, 03:58 PM   #4
chrismoore701
chrismoore701's Avatar
Check these guys out
http://wescoperformance.stores.yahoo.net
Expensive but real happy with them
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
