Closed Thread
Old 05-07-2016, 01:51 AM   #3651
1968aj
Re: What did you do to your truck today? Chapter II
Originally Posted by Dave K. View Post
Got the grill guard installed--bought it from a fellow member here. Okay, I drilled two holes--have left the outboard ones for now.... Thanks Al, great meeting you and thanks for your patience! Dave
looks right at home on your truck. nice meeting you too
1968aj is offline
Old 05-07-2016, 09:59 AM   #3652
Lanman1972
Lanman1972's Avatar
Finished the passenger side rust repair and to the drivers side!
Lanman1972 is offline
Old 05-07-2016, 01:50 PM   #3653
matthamby
Drove it home this morning from the shop where repairs were made to get it running and safe for the road!
matthamby is offline
Old 05-07-2016, 02:52 PM   #3654
jr1000yarder
Whos patch panels and how do they fit???
jr1000yarder is offline
Old 05-07-2016, 10:06 PM   #3655
66clow
66clow's Avatar
Got some new white walls . Pretty good deal from Wal-Mart on line. Hankooks. Now need some paint on the wheels.
https://goo.gl/photos/ac6RKzcBq3zpYa9w9
https://goo.gl/photos/ajYsxB6DZjB5TY8LA
66clow is offline
Old 05-07-2016, 10:28 PM   #3656
palallin
I removed and reinstalled the ignition switch, which had come loose, making it hard to start (I had to reach under and hold it still to turn the key). I also did a little lubing, so everything works much more betterer.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline
Old 05-07-2016, 10:43 PM   #3657
In The Ten Ring
Today I rust treated (NAPA Permatex) my windshield washer bottle bracket, wire wheeled the windshield squirter ends (Permatexed those too), and started doing the same to the tailgate chains.
In The Ten Ring is offline
Old 05-08-2016, 07:34 PM   #3658
Possmguts
Possmguts's Avatar
Finally got around to starting the bed... I will be pulling it apart but for now this is what I got done...
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline
Old 05-08-2016, 07:42 PM   #3659
fleetimus
fleetimus's Avatar
Tacked oil pump pickup and installed oil pump. (BBC) Was going to install oil pan, one piece gasket ripped. Time for a Bud.
68 Chevy l/b, 4 whl disc in the foothills of No Calif
fleetimus is offline
Old 05-08-2016, 09:19 PM   #3660
custom10nut
custom10nut's Avatar
I put my new seat belts in today. I've had them for over a year, but now they're in. Also fixed a couple broken springs in my drivers side seat. Now I don't feel like I'm sitting in a padded donut no more. Next, it's on to the dash......
custom10nut is offline
Old 05-08-2016, 09:35 PM   #3661
CST10
CST10's Avatar
Replaced a leaking power steering hose on ol Samson.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline
Old 05-08-2016, 09:47 PM   #3662
BenSherr
Got it started for the first time in months. I'm at a point where I'm seriously considering selling it. Got several other issues which are taking all my resources, and I don't see an end in sight. I am not the type to let a vehicle sit for too long, and mine has been sitting in my yard since Sept. Going to give it a few days and see if I can justify keeping it. If I can't I'll post it in the for sale section.
BenSherr is offline
Old 05-08-2016, 09:48 PM   #3663
ekgguy
ekgguy's Avatar
Said goodbye to the old rusted out cab
Brought in the new(er) one.
Matt
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=672655
"Father thank you for the gathering of friends, Father we give thanks for all the choices we've made because that's what makes us who we are, let us forever cherish the loved ones we've lost along the way and most of all THANK YOU FOR FAST CARS!"
ekgguy is offline
Old 05-08-2016, 11:26 PM   #3664
88Stanger
88Stanger's Avatar
finished the seat, custom lowered seat mounts and new belts
88Stanger is offline
Old 05-09-2016, 05:18 PM   #3665
70STOVEBOLT
70STOVEBOLT's Avatar
Not today, but over the weekend, I fixed a transmission leak at the speedo gear housing. The seal was leaking so I replaced it and the o-ring on the housing. Also picked and ground out the 40-plus-year-old drip rail sealer so I can apply new sealer to avoid future leaks.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline
Old 05-09-2016, 10:12 PM   #3666
Chucks72Longbed
Chucks72Longbed's Avatar
It wasn't today but over several days in the past month. New coils all the way around(someone heated them in the past,they were in bad shape). New shocks all the way around(still had the factory shocks on it. 44 years old). New brakes all the way around with new drums and wheel cylinders on the rear. It sure rides nice and stops good now.
72 Chevy C20 LWB-Just what I always wanted.
Now, just need more time and money!
Chucks72Longbed is offline
Old 05-09-2016, 10:51 PM   #3667
Metaldoc
Metaldoc's Avatar
Originally Posted by Bowtiguy View Post
If someone would have told me it would 5 days to cut, dado, router, drill, mock up install, reinstall, reinstall then get my custom 68' short wood bed on the frame ( after lifting it off to drill the gas filler hole) i'd say they were crazy. not anymore..
I doing a composite bed as well.
Metaldoc is offline
Old 05-10-2016, 12:58 AM   #3668
In The Ten Ring
Those built in tow hooks are pretty neat!
Old 05-10-2016, 12:59 AM   #3669
In The Ten Ring
I was able to get the squirters for the windshield painted. I just went with black although they were probably originally ochre.
Old 05-10-2016, 01:49 AM   #3670
66clow
66clow's Avatar
Definitely post the completion.
66clow is offline
Old 05-10-2016, 05:23 AM   #3671
Toms67
Toms67's Avatar
Striping and priming the frame. taking off front end and rear next.
Toms67 is offline
Old 05-10-2016, 07:07 AM   #3672
tlman
that's funny ,my rear cross member bent in exact same spot ,good place for chain with no bumper lol
tlman is offline
Old 05-10-2016, 05:00 PM   #3673
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What did you do to your truck today? Chapter II
I put a 11" booster back on the truck. Man it make a world of differance in stopping!
The 8" chrome looked better but it didn't function worth a crap!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 05-10-2016, 05:21 PM   #3674
In The Ten Ring
So those new-looking small ones aren't any good?
I think my brake booster came off some old junkyard Nova.
Today I used NAPA rust treatment on the firewall side of my heater box flapper, put a couple more coats of paint onto my tailgate chains, and I decided NOT to remove the flapper from the heater box. Members also told me how to clean up the outside of the box and to clear coat it.
Old 05-10-2016, 06:17 PM   #3675
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Andy your booster looks looks like it is tight to the firewall. How did you do you that ?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Already Gone is offline
Closed Thread
