Old 05-07-2016, 09:05 AM   #1
Oberon67
How fast will these things go, anyway?
The subject line says it. What's the fastest you've gone in a square body, either in acceleration or top speed?
Oberon67 is offline   Reply With Quote
Old 05-07-2016, 09:14 AM   #2
flashed
Re: How fast will these things go, anyway?
Mine is a 74 short step with 3 on the tree and a 250 /6 cylinder so not very fast .
flashed is offline   Reply With Quote
Old 05-07-2016, 09:26 AM   #3
Oberon67
I have the same drivetrain in an '81 long bed. A grocery-getter for sure, but I think I could bury the 85mph speedometer if I wanted to.
I haven't tried it. The reward doesn't seem worth the risk to me.
Old 05-07-2016, 10:39 AM   #4
TwoFiftyShifter
100 in my 87 V20. 4 speed 350. It wouldnt pull anymore after that;
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 05-07-2016, 10:55 AM   #5
KQQL IT
At the body shop.
KQQL IT's Avatar
1/4 mile
Old 05-07-2016, 11:26 AM   #6
Oberon67
Originally Posted by KQQL IT View Post
1/4 mile
Wow... Not too shabby!
Old 05-07-2016, 12:03 PM   #7
chrismoore701
chrismoore701's Avatar
I had my speedo pointed straight down. Put two quarts of oil back in after that run
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 05-07-2016, 01:58 PM   #8
Malo83
Cruzzzn' Vet
Malo83's Avatar
That's nothing, I can do that coming down the grapevine from LA to Bakersfield
Malo83 is offline   Reply With Quote
Old 05-07-2016, 02:14 PM   #9
KQQL IT
At the body shop.
KQQL IT's Avatar
Malo83 I have that double hump transmission crossmember, free to a good home.
Old 05-07-2016, 02:49 PM   #10
Malo83
Cruzzzn' Vet
Malo83's Avatar
PM sent.
Old 05-07-2016, 08:16 PM   #11
esbstuff
1990 or so... 78 k10, 350, 4-speed, 205, 3.07's. I had the speedo pointed straight down and bouncing one night. 3 wide on a 2 lane interstate with a couple buddies. I think the story was the last one at the party had to buy beer... I didn't have to buy! Too afraid I would go splat now.
esbstuff is offline   Reply With Quote
Old 05-07-2016, 09:29 PM   #12
Jake Wade
Jake Wade's Avatar
1/4 mile
That's impressive for a Small block truck if NA
Jake Wade is offline   Reply With Quote
Old 05-07-2016, 10:38 PM   #13
KQQL IT
At the body shop.
KQQL IT's Avatar
Yeah, for now.
Just rebuilt it with better rods and opened up ring gaps.
Try a hundred shot out of the hole is the plan.
Old 05-08-2016, 08:52 AM   #14
D13
D13's Avatar
1982 250 3ott 3.43 geared 3/4 ton, 80 is absolute limit.
1987 6.2 diesel 7004 3.08 geared 1/2 ton, fastest is 75, truck felt rock solid, issue was the noises under the hood.
I would suspect with a reasonable motor and OD trans with good gears that 120 would easily be possible. I read somewhere (Jim Feuling in CC in the 90's maybe?)that if the tailgate is open over 120 or so the vacuum bubble will close it - so I sure wouldn't want to try higher speed corners without some rear down force.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 05-08-2016, 09:05 AM   #15
phillip123hastings
So not really fast whatsoever.
phillip123hastings is offline   Reply With Quote
Old 05-08-2016, 12:08 PM   #16
KQQL IT
At the body shop.
KQQL IT's Avatar
3.08's @ 5500 with a 27" tire was way way faster that they should ever go on a S rated tire.
Thought the driveshaft was coming thru the floor when I lifted off the gas.
Old 05-08-2016, 12:19 PM   #17
Matt Man
Matt Man's Avatar
I had mine at about 90mph to test out driveshaft vibration when I had it rebuilt and shortened. Felt stable, but the wind noise was awful. I tried to push it farther as well but wouldn't go any faster. Oh well its a 81 4x4 pickup, not meant for speed haha.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 05-08-2016, 12:42 PM   #18
foamypirate
foamypirate's Avatar
Calculator says I should have been doing about 112 based on RPM (about 4200) in my 305/TH350/3.08/29" tire 84' LWB, but I have no idea how much converter slip was going on. Pedal was on the floor for several miles (sick baby in a truck with no AC in 97* temps, was trying to get home to get her cooled down ASAP). Wide open toll road, thankfully. Realistically, probably closer to 95mph based on how quickly I was passing people.
In my 88' R20 crewcab, max I've been is 90mph, testing acceleration with the LQ9/4L80E/4.10 combo. Speed limiter is 98mph, and the driveshaft is only good until roughly 115mph anway. I feel no need to take this one any faster than 90mph.
foamypirate is offline   Reply With Quote
Old 05-08-2016, 02:25 PM   #19
Oberon67
I'm thinking someone... Not me, someone who can build... should put together a square-body for Bonneville.
The World's Fastest Squarebody.
Old 05-08-2016, 02:53 PM   #20
mongocanfly
mongocanfly's Avatar
There's already a square body salt truck...210mph.http://67-72chevytrucks.com/vboard/s...d.php?t=473510
Old 05-08-2016, 05:28 PM   #21
mikentosh
mikentosh's Avatar
LS motors and lowered trucks are a wonderful thing...I took Cannonball C10 down to LA a few weekends ago and got into a fast moving crowd of Friday evening traffic. It was more than happy to cruise at triple digit speeds on and off for a couple of hours. In fact 6th gear is only useful above highway speed as its doing 2000 rpm at 80mph. I'm attributing the stability to lack of airflow under the truck and wide track; the front air dam sits only a couple of inches off the pavement.
Downside to this is that vertical windshield collects a lot of bugs at speed haha
Got a nice photo of it just off the 5 in Coalinga too
mikentosh is offline   Reply With Quote
Old 05-08-2016, 05:29 PM   #22
Oberon67
Interesting... But I bet someone here could beat it.
Old 05-08-2016, 06:51 PM   #23
Alex V.
Alex V.'s Avatar
Fastest I've had my '85 C3500 (454/TH400, 4.10's) is 85, but it wasn't done yet. 90 wouldn't be too hard, and I think it'd break 100 but everything under there is spinning so fast at that speed I'd rather preserve the truck than take the chance.
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Old 05-08-2016, 07:15 PM   #24
mongocanfly
My 81 c30 with 6.0, nv4500 and 4.10s will hit a 100 before you know it..when they had it on the dyno they had it showing 140..
Old 05-08-2016, 07:22 PM   #25
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Funny, Ive been thinking of taking my CCSB to the ECTA in Wilmington for the first race next year. It should be a C/PP or C/MP. No real shot at the record as C/PP is a 163 and change. Maybe run up in B? 5.3/4l60e 3.42 gears 29 inch tall tire 3500 through the traps is 130ish but that would be a real maybe. 115-120 is more realistic. Just got to run the numbers and buy some stuff.
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
