Old 05-09-2016, 10:17 AM   #1
Mr.Clean
1968 C30 Prerunner Build "Papa Smurf"
Well a little ways into my build now so figured I'd post it so i could more easily track whats going on with it. Long ways to go still tho.
I picked up a 1968 chevy c30 cab which was resting on a 1974 2wd c10 shortbox frame. No motor or trans when I bought it. Just roller with interior. Truck was a retired Chevron Oil work truck that was used in Texas up until 1994 when it was sold at auction to the gentleman I bought it from in Oklahoma where it sat in a barn since 1995. He is the one that did the body swap(set the body on the frame, never made mounts).
Basic plans are 4.8 ls with a 76 mm turbo. A but TH400 trans, linked 9" rear end, full cage, back half, fiberglass fenders and eventually bedsides, front suspension I am letting my buddy Neal who owns Griffen Fab works build a set of beams for it. Shocks will be 3.0" c/o's and 3.0" bypasses, and then I will be using my 2.0" profender bumps that i already have.
These pics are somewhat in order some aren't but after this post from here on out I will keep this updated so things are in order.
Mr.Clean is offline   Reply With Quote
Old 05-09-2016, 10:18 AM   #2
Mr.Clean
Re: 1968 C30 Prerunner Build "Papa Smurf"
Engine moved back 3.5"s. Tna xmember for clearance. Stripping harness. Motor mounts i machined at work.
Old 05-09-2016, 10:18 AM   #3
Mr.Clean
Old 05-09-2016, 10:20 AM   #4
Mr.Clean
These are NOT MY beams as mine are still at laser waiting to be cut, but these are a picture of the exact beams my truck is getting. I can't wait to get these under the truck.
I did get some work done tonight. Lots of welding. Got most of the back half welded up. Good enough to check out droop and bump with the back half and the glass fenders.
RIDE HEIGHT
BUMP (although this is an unrealistic bump as more then likely the beams won't be able to clear the motor this low)
DROOP
Old 05-09-2016, 10:22 AM   #5
Mr.Clean
Old 05-09-2016, 10:22 AM   #6
Mr.Clean
Making frame rails flat and straight for beam and steering mounts.
Old 05-09-2016, 10:23 AM   #7
Mr.Clean
First time the truck has moved off jack stands in months. Gonna be dropping the truck off at Griffen Fabworks Friday morning to get the beam work started. I backed the trailer back in the shop for now as i still have a few things I want to wrap up, but can't wait to see this thing with beams on it!
Old 05-09-2016, 10:25 AM   #8
Mr.Clean
This is where I am at with the build right now. I dropped the truck off last Friday at my buddies shop Griffen Fabworks for the beam work and am just waiting to get the truck back. Should be 4-5 weeks max I think and then will be getting on making that turbo motor run.
Old 05-09-2016, 01:24 PM   #9
Sicksty8
Sicksty8's Avatar
Badass project! I'm diggin the fab work and I'm in for sure
Sicksty8 is offline   Reply With Quote
Old 05-10-2016, 04:23 PM   #10
kehstr
kehstr's Avatar
subscribed sick truck!!
72 GMC highlander nicknamed by my then 6-year-old brother "stripes"
http://67-72chevytrucks.com/vboard/s....php?p=7378180
Check out my Youtube channel
@Chad's Fab
kehstr is offline   Reply With Quote
Old 08-17-2016, 08:59 PM   #11
Mr.Clean
So it's been months, but progress is finally underway.
Old 08-17-2016, 11:13 PM   #12
c10-72 II
Active Member
c10-72 II's Avatar
Where did you get the front fenders?
c10-72 II is offline   Reply With Quote
Old 08-18-2016, 04:12 AM   #13
Mr.Clean
http://www.hannemannfiberglass.com
Only company I found making them. 3" bulge and 1 3/4" wider wheel opening.
Still haven't found anyone that makes bulged bedsides for our year so I'll have to get more creative with that.
Old 08-18-2016, 10:47 PM   #14
Pinky6872
This thing is awesome, nice work!
My Dropmember Equipped Build
Instagram @chrispinkosky
Pinky6872 is offline   Reply With Quote
Old 08-20-2016, 12:49 PM   #15
tommys72
tommys72's Avatar
Cool build, ill keep watching now
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 08-21-2016, 09:04 AM   #16
Sac
Awesome build!
Green Survivor Father/Son Truck
<SeveredTies>
Sac is offline   Reply With Quote
Old 08-21-2016, 09:23 AM   #17
jeh
jeh's Avatar
I'm diggin the fabrication and welding ability. Keep it it up man, looking good!!!
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 08-21-2016, 07:12 PM   #18
mooseknuckles
mooseknuckles's Avatar
amazing build!
mooseknuckles is offline   Reply With Quote
Old 08-23-2016, 05:07 AM   #19
Mr.Clean
Got word beams and radius arms are fully welded so should have things mocked up this week.
Couple shots of the spindle assembly welded...BEEF!!!
Uses a d44 snout and hub assembly. I went with a ford 5x5.5" to match the rear 9".
One really nice thing about how he builds his beams is if i ever want to change or upgrade to a bigger snout/hub assembly i can cut out the backing plate and weld a new one in to accept the new snout.
Old 09-20-2016, 05:32 AM   #20
Mr.Clean
Well its only been like 5.5 months......and still ain't done. Started putting some pressure on today. I want my truck done and back. He sent me this.
Old 09-20-2016, 08:52 AM   #21
AnotherWs6
AnotherWs6's Avatar
Very cool.
1968 C-10 Suburban - Original 396/TH400
2002 Transam WS6 - M6 - Black/Black - Evil Garage Queen
2000 Silverado - DD - Small lift+Body lift+35" Duratracs+4.88's + Eaton TruTrac - Monster Truck
2010 Cadillac CTS Wagon Sport - Wife's DD and the only classy car we have.
AnotherWs6 is offline   Reply With Quote
Old 09-21-2016, 02:16 AM   #22
Foureye71
Foureye71's Avatar
Subbed
'71 K1500 Short-Wide
Foureye71 is offline   Reply With Quote
Old 09-21-2016, 06:08 AM   #23
Mr.Clean
Forgot this one as well
Old 09-22-2016, 08:19 AM   #24
Mr.Clean
Some radius arms looking like they are going on
Old 09-22-2016, 05:15 PM   #25
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice fab work! That front suspension looks like an old ford twin i beam on steroids!
Ryan
1969 Chevy milk truck
