What rear gear do I have calculation
I have an s10 that i'm trying to figure out my rear gear ratio without pulling the cover on. It's a 327 with a th350 at 60mph I'm running 2500 rpm my tires are 235/75R15's
Rust is better than rice. ![]() |
Re: What rear gear do I have calculation
Punch your numbers into here.
http://www.advanced-ev.com/Calculators/TireSize/ |
What do I put for diameter ? Sorry for the dumb question
You guys really need to learn the metric system!! LOL!!
I'm still learning it after 40 years of it. I'll give you the short answer, not the calculation. Usually a 235 is 29 inches tall. Actually 28.87 inches by calculation. Anytime you don't know a tire height, cross section etc just search for your size on tirerack. All the dimensions are there. |
![]() Join Date: Oct 2009
Calculates to a 3.55:1 rear, not exactly a common truck ratio - at least not for older trucks anyway. However, since you clearly don't have a stock setup and an S10 isn't "that" old, all bets are off - unless the 60 mph is from a GPS and not your dash (i.e. no way to know if the rear tire dia is stock to the rear gear/trans output shaft speedo gears, etc. If you do (or did) use a GPS, then it can be calculated more accurately. Below is for a TH400, but it shares the same 3rd gear final drive of 1:1, so it works for comparison. (I used 28.9" for the tire)
Thanks everyone I didn't know a whole lot about the truck i just bought it. It's an 84 s10 with with a 67 327 a th350 they 60mph was from the speedometer but has been checked against gps for accuracy
#7 | |
Probably time for the "spin the driveshaft method" (or pull the cover). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
At 60 mph with a 26" tall tire I was hitting right at 3K and those were 3.73's and I had a TH400 at the time. This was in a Monte Carlo I had at time.
