Old 04-28-2016, 05:05 PM   #1
89AKurt
89AKurt's Avatar
Driving light mounts
Thinking of adding additional driving lights (taking off the gold-plated money pit MINI before ditching it LOL). Where do I look for: 1. mounts 2. switch and/or relay. It worked to have connected with high beam switch before.
1968 C-10 Long Bed Blue Cloud
1956 GMC 100 GYMEE
1969 Corvette that identifies as a Ferrari Daytona Spyder Fakerri
2016 Honda Civic EX-T Stealth
89AKurt is offline   Reply With Quote
Old 04-28-2016, 06:53 PM   #2
geunther
geunther's Avatar
Re: Driving light mounts
Mine has Unity driving lights (along with a Unity spot light). I believe there were one of the dealer installed options at the time. The mounts come from underneath the truck and are bolted to existing frame homes. They are not attached to the bumper (which I like). They would be easy to replicate.
I don't necessary like the placement, but the fact that no holes were drilled makes me happy.
geunther is offline   Reply With Quote
Old 04-28-2016, 07:34 PM   #3
89AKurt
89AKurt's Avatar
Originally Posted by geunther View Post
Mine has UnityFACTORY driving lights (along with a FACTORY Unity spot light). I believe there were one of the STEALdealer installed options at the time. The mounts come from underneath the truck and are bolted to existing frame homes. They are not attached to the bumper (which I like). They would be easy to replicate.
THANKS FOR QUICK RESPONSE.
I can see making new ones that wrap around. But now they can be mounted to long straight application on TOP of the bumper, no cutting - thinking about various gap tolerance depending on visual). Switch?
1956 GMC 100 GYMEE
Old 04-28-2016, 07:37 PM   #4
89AKurt
89AKurt's Avatar
BTW: Comps on your '72 (didn't catch before clicking post, the proverbial pole shift AFTER pushing "send"). Lots of trim. >:^°
*edit* Probably against rules, I see something on top of the hood. I know about the second row just below door handle level. In architectural talk, the bottom one might be called sole plate, the second Chair Level or something. Just wanted to know the inside term for those. Drip edge (mine has some rust), wind wing, all I need is matt black spray paint to 70s it.
1956 GMC 100 GYMEE
Old 04-28-2016, 09:41 PM   #5
jeffahart
jeffahart's Avatar
I went ahead and made Swiss Cheese out of my bumper. It will be tough to make a bracket that snakes between the bumper and grill trim to mount on top of bumper. The flat iron has to be thick enough so the lights don't vibrate, and it's a tight squeeze. You can make a bracket coming up from the bottom easy enough though. Good light harness' are available but you can probably make one cheaper. I just hooked up some old PIAA 520s but I still had the harness. Here's a pic, even though you're not into the Swiss Cheese method!
PIAA 520s are wired into bright lights, and also uses a switch.
White K20
jeffahart is offline   Reply With Quote
Old 05-13-2016, 01:54 AM   #6
89AKurt
89AKurt's Avatar
Thanks jeffahart!
I just about got it done!
Call this Cheapskate Driveway work, I used up aluminum C-channel that I made a mailbox post out of. I avoided drilling any holes!
First step, to make the part that used the bumper bolt, simply used a new nut to attach.
Peeking between the bumper and aluminum grill.
The pieces of the mounts were made from the same aluminum. Tolerances were about 1/16". Used a jigsaw for the big cuts, then a handsaw. Drill press came in handy. Tapped threads in the first mount, allen screws were set with Loctite. Kinda hard to finish the wedges on the disk sander. Yes, I'm more of a woodworker than a mechanic.
Don't know if this happens to others, but it's always the second part that becomes a PITA to finish (sorry for the crappy night shot).
1956 GMC 100 GYMEE
Old 05-13-2016, 11:16 AM   #7
jeffahart
jeffahart's Avatar
Nice job. Those look great!
White K20
Old 05-13-2016, 11:19 AM   #8
Andy4639
Old member
Andy4639's Avatar
Talking Re: Driving light mounts
I have mine molded into the bumper. I like mods on my truck. Its a driver!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 05-13-2016, 11:56 AM   #9
89AKurt
89AKurt's Avatar
Thank you!
1956 GMC 100 GYMEE
Old 05-13-2016, 11:59 AM   #10
89AKurt
89AKurt's Avatar
Better day pictures.....
Didn't realized what a PITA it was going to be to tighten the nut for the light!
Just need a roll cage to enter in a rally.
Ultimate test will be driving on a washboard road.
1956 GMC 100 GYMEE
"driving lights", mount
