Old 05-13-2016, 02:01 PM   #1
sharkskinman
Clutch adjust, 66 250, 3 tree
Noticed they my clutch for rests on my frame.. Now with new motor it feels as if the clutch needs to be adjusted
Feels as if it's not releasing completely
I have rod with V shaped end that rests in the clutch fork
If I adjust it forward it will release it fully but will it slow it to engage fully?
Or am I going to have to bend the rod to clear the frame?
sharkskinman is offline   Reply With Quote
Old 05-13-2016, 02:24 PM   #2
RANDY COX
RANDY COX's Avatar
Re: Clutch adjust, 66 250, 3 tree
not sure I quite understand what your saying but pictures sure would help...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 05-13-2016, 06:50 PM   #3
sharkskinman
Pics
Old 05-13-2016, 09:13 PM   #4
padresag
is your truck a chev or gmc?
ron
padresag is offline   Reply With Quote
Old 05-13-2016, 09:53 PM   #5
T and S
T and S's Avatar
from your pic, it looks like your z - bar has slid over far enough that the linkage is hitting the frame. Their should be a snap ring in your z - bar assembly that holds the ball in position. Yours is missing or broke, allowing the side shift of your linkage.
If you don't like this pound sand .....
T and S is offline   Reply With Quote
Old 05-13-2016, 10:05 PM   #6
padresag
that is more than likely it or the bushings are missing and worn out. there is a bend in Chev Zbars and I believe that the GMC are straight across. was why I asked that question above
ron
Old 05-14-2016, 02:16 AM   #7
sharkskinman
Chevy
Doesn't seem like it's fully disengaging either
So adjusting the rod just so before it touches the TB fork?
The spring should keep it tight but I should have 1-2" of free play at the top of the peddle travel?
It doesn't engage till almost the top
Any diagram showing this exact clutch linkage?
Old 05-14-2016, 09:28 AM   #8
T and S
T and S's Avatar
Your throw out bearing should have enough clearance not to spin when clutch is engaged. Best way to make sure is to remove inspection plate below clutch, then you will be able to see your free play. Here is a exploded view of clutch linkage:
