Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-03-2016, 11:02 PM   #401
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Well , im loading up my junk tomorrow . I have 3 fresh bottles and 4 full gas jugs , a fresh motor and 2 new sets of slicks . It will be on this weekend . Just focusing on my program and off we go .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 03-07-2016, 12:29 PM   #402
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Things were going good and after a 3rd round win I pull back to the trailer and jump on the scooter headed to watch the rest of the round . I get back to the truck and water is everywhere . I top It off and run the water pump ......no leaks . Start it up and it blowing water out between front of head and block . Lost the driver side head gasket . So I load up the yellow truck on a borrowed trailer and truck and haul it home to swap it for the blue truck . Was .001 to a .056 and couldn't get there . Left 6 numbers on the big end! 7.41 on a 7.35 dial. I was about to load up and my buddy wont let me . Bought back in and went 2 more rounds . I was like .038 and he was .027 . I only had .011 and took .013 for the break out . He dumped for the win . Anyway pics .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 03-08-2016, 05:53 PM   #403
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Heads were unshrouded to 4.100 for 4.125 bore and we used 4.060 gaskets . Smallest was 4.070 so fire ring was in chamber . Once it got enough heat to break the fire ring it pushed compression passed the sealer part of the gasket . Each hole had marks from the chamber edge in the ring . TO get the quench correct we ordered 4.165" .029 . This will be more than enough and only lose 1 CC per hole . Head and block is good . I am about to pull the passenger side head . Ill try and get pics together.
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 03-09-2016, 12:10 AM   #404
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Got it apart , going back together tomorrow . Racing both days next weekend .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 03-10-2016, 10:19 PM   #405
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Got this thing back together . Set the valves to the cam card at .022I and .024E . It was a noisy SOB and ran like crap . Reset them at .020/.020 totally different motor . Next go round will be .018 for all them . Ready to go for the weekend . Need to bolt the hood back on and double check the timing . The first batch of fuel I got was 84% . I only bought 2 jugs . 5 days later I bought 3 more jugs they are 76% . I will drain the 84% and switch to 76% which should put my A/F ratio dead on . We will see .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 03-13-2016, 10:36 PM   #406
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Well this thing is fast .6.39 fastest pass . I cant keep it from going red . don't know what to do and about to give up . .........Pics as always ....anybody even read this?
My blue street ruck with my machinists son driving it .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 03-14-2016, 12:54 AM   #407
chevybuldr
chevybuldr's Avatar
Re: New project
Do you leave off a trans-brake or foot? If Trans why not try an adjustable button?
chevybuldr is offline   Reply With Quote
Old 03-14-2016, 07:45 AM   #408
regan wilson
regan wilson's Avatar
Re: New project
Looks like its running good HotRod. How red are you going? Arent you already using an adjustable T/B switch? Can you fit a taller front tire? Questions questions lol
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 03-14-2016, 10:26 AM   #409
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
I have an adjustable button in it already , gonna try dropping leave RPM .
Going to try a set of 26" fronts also . That right lane is still messed up and nobody will fix it . Hopefully after the national nhra will fix them .
Just almost too much work Truck has been on jack stands for the last 4 races . This weekend was no different . Guess I missed tightening a head bolt and had a water leak . It filled the diaper up with water and one of the header tubes burned through and found water . Had to drop the exhaust headers and front crossmember in the pits to get it off before first round . It was full . Found the leak in a head bolt and tightened it . Water leak stopped . I actually lost a round last sunday other than that red first and second round . On a good note swapping to 76% made the truck A/F ratios perfect and very consistant .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 03-15-2016, 07:38 AM   #410
regan wilson
Re: New project
Hotrod It looks like you may be yanking the front tires out of the beams. If you have an adjustable front ladderbar crossmember you could try lowering them one hole. This should make the truck move forward more instead of upward. Or like you said change the launch rpm( I move mine as much as 600 rpm throughout the year) because i do a lot of my setup by 60 ft numbers. I dont know that there is still a problem with that right lane. NHRA sets up our stuff starting on Fri morning at our races. Hence my numbers in my delay box are .030 less from the TNT numbers on Thursday(local track setup)
Old 03-15-2016, 11:51 AM   #411
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Im leaf spring and Caltracs . So changing pinion angle is a no go . I am just thinking im gonna try moving launch rpm and tire pressure together . Say 36# @ 3600 rpm if im late i'll go 3700 and 37psi and so on . Im at 4200 and 44psi now .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 03-15-2016, 02:55 PM   #412
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
https://www.youtube.com/watch?v=2uJ3...yer_detailpage
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 03-20-2016, 02:37 AM   #413
JJLT1
JJLT1's Avatar
Re: New project
still readin, and movies now too, wow
49,306 views someone's lookin..
you re-torque the head gaskets after a heat cycle??
I torq-ed mine waited a week, found a loose one..
and still found a loose one after a heat cycle, with felpro permatorq's..
JJ
71 SWB 360 Th400 4.56
JJLT1 is offline   Reply With Quote
Old 03-27-2016, 03:45 PM   #414
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Been working on this thing and it started leaking water again from the small head bolts . I pulled both headers and valve covers to do a retorque on the heads . All the bolts were tight at 70#s except the lower small bolts and every one of them to 1/4 turn to get to 70#s . These are new ARP bolts . Initial torque was to 75 and no threads pulled as they all reset to 70# without stripping . I don't know if they stretched or what , but it stopped leaking water ......for now . I have an oil issue in the front , but it is more of a film then a leak . and I have a trans drip now and then so ill check that out this week . I also went up 1 jet size in all 4 corners.
If your up to date on this you know I have had issues with red lighting with the new combo . I have been leaving at 4200 with 45# in the 25" fronts and 14 in the rears . Well I made some changes for this weekend . dropped the 2 step to 3500 and set the fronts at 40 # . I run IHRA at Ben Bruce memorial racepark in Evadale , Texas and yesterday was the season opener . So first time trial im .020 red .
I cooled it down and moved the 2 step to 3000 and the fronts to 34#
and was .031 green ....which was actually a relief to me .
Cooled it down again and topped off the air and headed to first round thinking .031 was better than red . I added 2# to the fronts @36# and left the 2 step alone . Ended up with the 1st round W with a .022 light and scrubbing 5 mph at the end .
Brought it back and cooled it down again and set up like round 1 and the dam .022 got me the bye . Since I had made a pass in the right and I ended up with a single I chose the left . .000 and 7 slow . The left lane was bad .
Again I cooled it down and set up the same . After 3rd round they swap to a ladder and the best reaction time has lane choice . I chose the right lane better of the 2 and a faster car . set up a bit soft from the.000 .
and was .074
They stacked the ladder again and amazingly I got lane choice again . Chose the right lane again Way late , but dead on 9 and she spun and I found the hole .
Headed into the finals and I definitely do not have lane choice . I dial up 5 on what my split time tells me and start heating the bottle . Everyone has spun in the left lane , but most are on some sort of radial . I slow down extension on the rear 1 click and head up to the line . Sure enough I got the left lane . I told my opponent " you keep your Hoosier radial , ill keep my bias ply , 300 shot and the lane you don't want " . did a big burn out and BAM! .....it hooked . I tree'd him by .011 and took.008 strip on a double breakout for the win .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 03-27-2016, 04:35 PM   #415
chevybuldr
chevybuldr's Avatar
Re: New project
Congrats thats got to feel pretty good with all the troubles you were having!!!
Old 03-28-2016, 06:59 AM   #416
djracer
djracer's Avatar
Re: New project
Congrats Great Job.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 03-28-2016, 03:29 PM   #417
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Cell phone video.
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 03-29-2016, 08:29 AM   #418
regan wilson
Re: New project
Good job Hotrod!
Old 04-01-2016, 06:07 PM   #419
JJLT1
JJLT1's Avatar
Re: New project
wow
wtg HR
JJ
Old 04-13-2016, 03:05 PM   #420
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Well im in the points lead for now :
Evadale Raceway
No Box
New SSS Summit Points
2016
Car #
Driver's Name
Points
LX34 Belluomimi, Devin - Santa Fe, TX 20
1x68 Bozeman, Steve 20
4X15 Hutto, Justin
30
KXJ98 Lindsey, Keith
30
LXX8 Lissman, David - Pasadina, TX 30
4X67 Lummus, Donna - China, TX 50
BX27 Martin, Randy - Vidor, TX 0
TX62 McCauley, Glover - Lumberton, TX 62
4X78 Miles, Richard - Lake Charles, LA 0
BX64 Morgan, Wayne - Port Neches, TX 0
4X6Q Patterson, Jason - Highlands, TX 81
YX41 Smith, Paul - Tomball, TX
40
4X19 Stelly, John - Hamshire, TX 0
4X50 Styron, David 0
4XSS Wray, Raland - Baytown, TX 82
XX52 Winn, John - Deer Park, TX 0
1X70 Wolfford,Eric 20
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 04-24-2016, 02:09 PM   #421
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Put another W in the books last night . anging on to that points lead , but man is it tough .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 04-25-2016, 08:45 AM   #422
regan wilson
Re: New project
Good job Hotrod!
Old 05-04-2016, 10:11 PM   #423
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Chapter 4 coming up . Im hanging on by 2 points . hoping for the best . We will see.
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-13-2016, 07:55 PM   #424
JJLT1
JJLT1's Avatar
Re: New project
WTG
JJ
Old 06-12-2016, 11:02 PM   #425
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Well a quick update I am 5 rounds out of 1st place in IHRA now guess I had converter issues . The sprag was bad . Going fender well headers and front coil overs . Losing 150 # in torsion bars and cross members . Also bought a really nice Hughes cased glide and my rebuilt wally winning ATI converter . Should b3e 6.0? still no electronics .
Thinking about building a 7.0 / 10.90 truck .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
