Old 05-14-2016, 01:33 PM   #1
In The Ten Ring
Another windshield washer question.
Hi again everybody!
Since I am going to switch to a more modern pump, is there a hose fitting made into a "Y" shape that will allow a single hose from the new pump to supply both squirters?
I've found several such connectors online, but can anyone show me what they used?
In The Ten Ring is offline   Reply With Quote
Old 05-14-2016, 01:45 PM   #2
cdowns
cdowns's Avatar
Re: Another windshield washer question.
go into local autoparts store and look or at best ask for sum help
Old 05-14-2016, 02:36 PM   #3
Andy4639
Old member
Andy4639's Avatar
Talking Re: Another windshield washer question.
Originally Posted by In The Ten Ring View Post
Hi again everybody!
Parts store. Look for the vacuum fittings box. Should have several tee fittings. Just pick the right size for the hose.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 05-14-2016, 03:53 PM   #4
In The Ten Ring
The auto parts stores....I just never imagined they carried such things. I'll have a look next time out. Thanks.
Old 05-14-2016, 08:06 PM   #5
AlbertaClassic
If you are planning on buying a new pump at a store, they often come with fittings. My pump new from NAPA was $20 Canadian and came with everything I needed.
AlbertaClassic is offline   Reply With Quote
