Old 05-14-2016, 03:19 PM   #726
TJ's Chevy
TJ's Chevy's Avatar
Re: 61K10 build
Originally Posted by 61K10 View Post
Finally got the tk back on the road. The new disc brakes are night and day from the power/drums set-up i had. It was worth the $$$ and time spent adding them to the closed knuckle axle. Now about the steering with the 4deg shims added to the ft axle. It has much more feel and not wanting to wander as it did before. Another plus! Need to drive it some more of course. also need to run it in 4h to get the ft ring & pinion broke in some. I actually used it as a tk, went to ACE and got some dirt/potting soil for my garden. It still makes a nice gear wine going down the road under power and deceleration, but free wheeling it's quiet. old sm420 and a 221 i guess!
A pic for you TJ---a working tk lol.
Hey hey! lol! Don't scratch the paint now!
Old 05-14-2016, 03:26 PM   #727
RANDY COX
RANDY COX's Avatar
Re: 61K10 build
Looking good Kimble I like how you added back those reflectors below your tail-lites...
sumthin bout a truck...these truck were work horses back in the day...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 05-14-2016, 03:57 PM   #728
61K10
61K10's Avatar
Re: 61K10 build
Randy--when i was in high school i had a 58 chevy sfb pu and took it to school in the 10th grade (just got my lic). the hwy patrol inspected my tk for safety. they said i had to add reflectors as the tail lights did not reflect. I have seen a lot of them on old tk's of all makes.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 05-15-2016, 12:41 PM   #729
61K10
61K10's Avatar
Re: 61K10 build
Thanks Jason--I still need to make my headache rack, some more under coating and sound deadening and maybe air down the road. When i win the lotto i will buy a new bed lol! What have you been doing with your two?
1961 chevy K10
Old 05-24-2016, 11:04 PM   #730
aotte1
Re: 61K10 build
Kimble,
Did adding the disk brakes increase you Dana 44 front axle WMS to WMS width?
My '64 WMS width is 65 1/2" and the '79 disk brake Dana 44 is 67 1/2". Just for information will measure the spare '69 K20 Dana to see its WMS width.
Trying to determine the front wheel/tire track that looks original/ good. Will likely put the core support and one fender on the frame to see how it looks currently.
Thanks,
Les
aotte1 is offline   Reply With Quote
Old 05-25-2016, 01:33 PM   #731
61K10
61K10's Avatar
Re: 61K10 build
Les--will set my old stock spindles next to my new spindle set-up and measure. will post up a pic.
1961 chevy K10
Old 05-25-2016, 03:33 PM   #732
61K10
61K10's Avatar
Re: 61K10 build
Les--looks like 9/16" wider than stock. (disregard caliper bracket just floating). the open knuckle hubs are shorter also. My rear axle is narrower than the front at 62". I bought the 1 1/2 wheel spacers for the rear, but they looked funny looking under the tk at the wheel. Don't know why they built the front and rear axles that way.
1961 chevy K10
Old 05-27-2016, 02:03 PM   #733
aotte1
Re: 61K10 build
Kimble,
Thanks for the photos, they are helpful. Gives more information on front track, for different options when adding disk brakes.
Thanks,
Les
Old 06-09-2016, 01:01 PM   #734
aotte1
Re: 61K10 build
Kimble,
Looks like I need to change out the seals on my Rockwell T221. Just sitting their and spinning it makes it leak some. Did you change your out? Getting the seal from a person who has a lot of parts for the T221. Planning to double up on shaft seals per his suggestion. Also, will epoxy two magnets to the bottom cover to collect small metal wear parts. He reports these guys generate some metal as they wear. Also " we are much better of having the divorced 221 as they do not have the imput shaft issues the married ones have".
Did you get to find the van brake hose part numbers you are using.
Les
Old 06-09-2016, 07:10 PM   #735
61K10
61K10's Avatar
Re: 61K10 build
as i said earlier the brake lines are from i think a 75 p30 and are 23"+ long. (rockauto lists most specs) sense you are using a different axle, measure what length you need. I have very limited travel in my ft axle due to my pto drive-shaft.
1961 chevy K10
Old 06-09-2016, 10:03 PM   #736
aotte1
Re: 61K10 build
Kimble,
Thanks, will check out Rockauto.
Les
Old 06-10-2016, 12:29 PM   #737
aotte1
Re: 61K10 build
Kimble,
A question on your rear wheel location PLEASE!
Have a plan for my front wheels now. Going to move each wheel in one inch from where they are now.
Currently have 3" BS on 16x6", will change them to 4" BS, because I have the '79 axle.
Working on rear wheel position now. Current setup has most outer lip of wheel, 7" from outside of spring pack. Photo of how I measured mine. If you have time, can you measure yours please.
All your photos/information showing your trk wheels/tires is a big help, in getting the stock look. Mine came with 10" wheels.
thanks,
Les
Old 06-11-2016, 10:10 AM   #738
61K10
61K10's Avatar
Re: 61K10 build
Mine are about 6" but i have an HO-33 eaton rear axle. at 62" wms to wms.
1961 chevy K10
Old 06-13-2016, 01:45 PM   #739
aotte1
Re: 61K10 build
Kimble,
Thanks for the measurement on your trk. Mine measures around 63.5 WMS to WMS, ( 63.5 is what CaptainFeb says for "C" trucks with newer 12 bolts, later '70 and up). So it is .75" per side wider then yours. Originally thought it was a '65 axle because the gears were dated '65, however, fooled me as it is a newer axle.
Do you think the .75 wider axle each side, and 16x6 wheels, same as yours, will fit nicely in the rear wheel wells? You said earlier you tried some wheel spacer, however, did not like how they looked, from under the truck. My wheels are like yours with centered BS. If needed, to move wheel and tire in more, I can increase my BS from the centered 3" to 3 1/2 or 3 3/4 " easily.
Also, the 235x85x16s are about 0.3"s wider each side, then the 215s. So in total my wheels/tire will be about 1" wider in the wheel well.
Thanks,
Les
Old 06-13-2016, 04:24 PM   #740
61K10
61K10's Avatar
Re: 61K10 build
Les--should be just fine with that axle and wheels, and should look good also.
1961 chevy K10
Old 06-13-2016, 11:58 PM   #741
aotte1
Re: 61K10 build
Kimble,
Thanks, sounds good.
Been trying to rebuild my front calipers that came with my '79 Dana 44, just could not get the pucks out, after hours of trying. Feel they are to corroded to reuse if I could get them out. Going with rebuilt A/C Delco fully loaded ones for about $50 ea.
Once they are installed, will measure what length brake hoses needed, and then off to "Rock ...." To find them.
Thanks,
Les
Old 06-14-2016, 12:36 PM   #742
61K10
61K10's Avatar
Re: 61K10 build
Les-- here is a pic again of mine. They have a bend just after they bolt to the calipers. disregard the tubing on the other end. I have used compressed air to remove the pucks, just be careful lol.
1961 chevy K10
Old 06-14-2016, 08:26 PM   #743
_mg
Active Member
_mg's Avatar
Re: 61K10 build
Great details, you guys are going to save me so much time...eventually. Glad to follow both of your builds.
_mg is offline   Reply With Quote
Old 06-15-2016, 01:01 PM   #744
61K10
61K10's Avatar
Re: 61K10 build
_mg what are you building?
1961 chevy K10
Old 06-15-2016, 08:45 PM   #745
_mg
Active Member
_mg's Avatar
Re: 61K10 build
I have a '64 K10 LWB like Les'. Not actually doing much with it at the moment, hoping to get some time this summer. In the meantime, learn, learn and more learn!
Mike
Old 06-15-2016, 10:04 PM   #746
aotte1
Re: 61K10 build
Kimble,
Got my new ACDelco fully loaded calipers for '79 Dana axle and they seem to not fit, maybe to tight. Need to do more research, and get my cores back, and see any difference. They looked generally the same, next will do some measurements, to find differences. First will check to see that they are correct for the DB5 brake option. It has the thicker rotors at 1.25" vs standard at 1". All '79 K10s should have the 1.25" front rotors. These calipers may be for the standard rotors, the box part number is correct for '79 to '80 K10. The caliper piston is also bigger diameter with the DB5 option too.
Checked out the caliper hoses on Rockauto, found P10 and 20 hoses in the range of 20 to 23" long. The stock '79s are 18" long. The end hose fitting to the hard brake line is a little bigger then the stock '64s. Not sure how to accommodate this yet. All the brake lines are undecided, as going to dual MC and disks up front, requires changes. May just make them.
Les
Old 09-23-2016, 04:30 PM   #747
61K10
61K10's Avatar
Re: 61K10 build
Had a new front driveshaft built as my old one was bent. had a wobble to it. also a new lis-plate with the correct numbers. You 4x4 guy's need to post up on your builds.
1961 chevy K10
Old 09-23-2016, 08:07 PM   #748
RANDY COX
RANDY COX's Avatar
Re: 61K10 build
Lookin good Kimble as always, I've just been driving mine more and more I attended a flea market last Sat and Sun and got to keep my truck in there behind me I must have had 20-30 people ask if it was for sale, I said shoot no, had some people say they used to have one and sold them and wished they had them back....The truck drew more attention than the stuff I was trying to sell...I kinda want to experiment before it gets too cold..I think I'm gonna go with a patina look for now...
1964 BBC 402 4x4
Old 09-23-2016, 09:00 PM   #749
argonaut
argonaut's Avatar
Re: 61K10 build
Awesome plates, K!
I have amassed a lot of parts and plan to start working on Big Ugly again in January. Can't wait.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 09-23-2016, 11:02 PM   #750
aotte1
Re: 61K10 build
Kimble,
Very nice, I am starting back on 64 K10, been cleaning bolts and other small parts. Will be posting soon too. We just sold our home this week, and that will free up, a lot of time. Had been keeping up two homes. Now just a little unpacking, smile. Need to run a 240 volt line to the garage, for air compressor and welder. Still waiting for painter to be ready for body.
Got a bad bug today - looking at another 60-66 truck, SB, fleet.
Les
