05-14-2016, 05:46 PM | #1 |
Idle/clutch issue
67 c20 v8. When i push the clutch in the motor revs real high. Truck hasn't been started in ten years
05-14-2016, 08:12 PM | #2 |
Re: Idle/clutch issue
Could be a broken motor mount..watch the engine while you push in on the clutch.
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. Last edited by hamjet; 05-15-2016 at 06:22 AM. |
05-14-2016, 08:42 PM | #3 |
Yeah. '67 (throttle linkage, not a cable) might be affected by a purely mechanical interference. That or you've got something bad wrong in the clutch/tranny that's causing a lot of drag.
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
05-14-2016, 10:54 PM | #4 |
Thanks ill try to get a better look tomorrow
09-03-2019, 01:14 PM | #5 |
Having a similar issue. Did you ever figure out the cause?
09-03-2019, 01:29 PM | #6 |
The Older Generation
The OP hasn't been on the board since 10-07-2018 09:30 AM.
Does your truck have the throttle rod or cable linkage? LockDoc
09-04-2019, 03:10 PM | #7 |
I know it’s an old dead thread. Thought it was worth a shot, he might get an email notification and reply.
My truck has a cable. When I clutch in, (in or out of gear) the Rpms increase. I don’t have a tach, so I’m not sure by how much. I would guess 200-300 rpm increase from a clutch out and neutral idle. |
09-04-2019, 05:08 PM | #8 | |
That was a common problem with the linkage rod if the rubber motor mounts were separated or broken, but not so much with the cable. That's why they changed them over. I would still check the engine and bell housing rubber mounts and see how they look. LockDoc
09-04-2019, 09:43 PM | #9 |
Thanks for the reply.
I’ll look it over for sure and have the wife work the clutch while I check for movement of the block. Any other known causes for a clutch in rise in RPM that I might look for? TIA |
