#26 |
Re: '68 C30 Cummins swap
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
#27 |
![]() ![]() Join Date: Jan 2015
Very nice I want to do this with my 68 later on down the road
#28 | |
BTW, your build is making me think twice about keeping mine 2wd!
#29 |
#30 |
![]() Join Date: Nov 2008
here is what I did for the mounts. Worked pretty well, however the engine in a 2wd set up is very tight and I spent a long time getting the engine sitting exactly where I want it (not easy with a 1300# engine). It fits with a little room to spare on the firewall and a little room to spare with the front cross brace.
Hopefully that truck has a high hump floor or you'll have some serious cutting to do. If it has a high hump, a 1" body lift gives you enough room to fit everything. http://67-72chevytrucks.com/vboard/s...d.php?t=694686 |
#31 |
Thanks for the link, your truck looks great!
It has a high hump and after removing the AC compressor I have it where I want it. I plan to build a factory style engine side mount and the '93 lower isolators. For now it's on standby, wife had a baby boy on Thursday(our 3rd)! ![]() ![]()
#32 |
6>8 Plugless........
![]() Join Date: Sep 2007
Congratulations on the new little one! Good luck getting any time to work on the C30 now!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#33 | |
I'll be at it soon enough.....the pile of parts is in my way!
#34 |
Had a chance to fab the engine mounts out of 5/16" and 1/4" plate.
Hopefully will have the transmission mount done this weekend so I can wire and start the intercooler piping. ![]() ![]() ![]()
#35 |
Almost forgot, picked up an '84 CCLB dually frame for my disk brakes, was only $100 and scrapped what I didnt need for $25!
Came with a pair of these hoping I can find 4 more, polished up they would look pretty nice. ![]()
#36 |
double post
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback Last edited by projectking; 06-18-2016 at 05:52 PM. |
#37 |
Looks good I haven't done anything to mine lately but I did pick up a 91 dodge with 195k on it with a 5.9 5speed and 205 frame was rusted bad so one day
#38 |
Perfect, swap it while it's still apart. I'm on my back modifying the GM trans mount to work with the getrag wishing the cab wasn't in the way.
#39 |
All about them K’s
![]() Join Date: Jun 2014
This is cool! I build 12v 5.9s at work. I've built 2 in the last 3 weeks and have another block, head and crank at the machine shop as we speak. I've been thinking about building a nasty 12v for my K20. A one inch body lift is no big deal to me.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
#40 |
I didn't have to do a body lift, or any cutting. With engine on the crane I picked it up letting the transmission angle down, once it was past the crossmember I used a floor jack to raise it and roll slowly as the engine came down/in. Have to say I was surprised how well it fit in there(once the AC and heater box were removed). I plan to get the bracket to raise the compressor and I will probably end up flipping the exhaust manifold so it clears.
#41 |
Subscribed! Great build. I really been wanting to do this but with a 1/2 ton i think the 12v is a bit much for the rails. 4bt motors are nice but real expensive as well.
#42 |
Mounted the fenders and hood last night and did some mockup....
Dodge radiator is too tall by roughly 2" and the GM radiator is too wide for the first gen intercooler.
#43 |
The hood will still close with the Dodge radiator if you still wanted to use that. I am running it.
#44 |
I had it in and it's 2" from closing, I'm guessing the slant nose is the culprit.
What did you do as far as the wiring, and were you able to use the stock voltage reg?
#45 |
Oh yeah, forgot about that being a '68.
Luckily those engines don't need much of a radiator to stay cool. They run cool to begin with. I'm sure a universal radiator would work fine. |
#46 |
Just went back through your thread and saw your non intercooled and have a different radiator than I do.
#47 |
Finally able to get some time with the truck.....well sort of, removed the disc brakes from the dually stub and hoping to get everything swapped onto the '68. Also using the power steering and sway bar/braces.
#48 |
Nice project you have going. You will love the 12 valve after your done. Also, Congratulations on the new birth.
1987 GMC R2500 SC 454 T400 1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors |
#49 |
Thanks!
#50 |
Today was a great day to work outside, perfect temperature!
Finalized the disk brakes and swapped the gearbox/steering parts from the '84, got the core support cut and the intercooler and piping installed. Can't believe that I was able to use everything from the dodge and only had to trim the intercooler mounting tabs so they clear the headlights. Waiting on a custom radiator to be built and I should be able to fire it up next week, already bumped it over with the key! ![]() ![]() ![]()
