05-15-2016, 02:14 PM | #1 |
Axle seals leaking
I just installed the axle in my 79 after sitting for many years. The front seal and one axle seal leaks. Can I get away with a stop leak additive? If so for how long? No problem on pulling it apart and replacing seals. But don't want to do that until this winter
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart My build 2008-2016. http://m.imgur.com/a/bURrE |
05-15-2016, 04:19 PM | #2 |
Re: Axle seals leaking
I would not do the snake oil, fix it right.
05-15-2016, 06:01 PM | #3 |
1. Long distance daily driver or occasional use only?
2. A few drops on the ground or half a cup? 3. Are you ok with doing frequent pull the plug oil level checks? I see no problem with stop leak as long as you plan on seal replacement fairly soon. Think of the stop leak as a scheduling aid, not a long term fix. The seals probably hardened during the down time and cracked when the axle was returned to service. |
05-15-2016, 06:29 PM | #4 |
No drips. Just sprayed on bottom of bed. Just occasional use. Looking to get to winter and tear it down then
