05-16-2016, 02:32 PM | #1 |
Control arm replacement options - CPP?
In disassembly of my 70 front end this past weekend, I found why the truck had a slight lean I could never get rid of (ended up cutting a coil to level it). I have a slightly bent lower control arm. It wasn't visible until I pulled out the control arm shafts.
Now I need to decide what to do. I was going to sandblast and paint these originals, rebuild everything with moog and put it back together. I'm not sure I want to try to bend it back right. Should I try to find a good used replacement? Should I try to find a reproduction? Tubular a-arms aren't in the budget right now unless I go with the less expensive options. For example, Summit (on their ebay site) has CPP 6372TCA-LKB control arms for $326/pr. I could run those lowers with my stock uppers for now. Does anyone have any first hand experience with these? Is there a better alternative? (I'll go hotchkis if we hit the powerball) I loathe CPP and their "customer service shenanigans" but am not familiar with the others out there and don't know if they are any good.
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
05-16-2016, 03:06 PM | #2 |
Re: Control arm replacement options - CPP?
Your cheapest option would be to head to a salvage yard and get one there. I wouldnt try to bend it back. I would just stay stock for the money, aftermarket in my opinion is if your trying to lay frame or building a pro touring truck.
05-16-2016, 03:15 PM | #3 |
I bought the CPP stock style arms (I got mine from summit too)
http://www.summitracing.com/parts/cl...del/c10-pickup http://www.summitracing.com/parts/clp-6372scal When I pulled my suspension apart for the 4/6 drop I found my upper and lower control arm bushings had a fair amount of wiggle. It was expensive, but I didn't have time to strip, clean, and rebuild my stock ones with new bushings (not cheap either.) They appear to be just as heavy as stock. It was tricky getting the lower shock bolt in, but it's tricky with the factory ones too.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
05-16-2016, 08:26 PM | #4 | |
05-16-2016, 08:29 PM | #5 | |
Thanks!
05-16-2016, 11:15 PM | #6 |
They come assembled, which is another reason why I bought them. If you already have the shafts and new bushings and are OK with swapping them, I would go with some used arms and save a pile of $.
05-17-2016, 08:27 AM | #7 | |
Its pretty appealing to say screw it and get the pair of new CPP ones. Nice, straight, clean, powdercoated and ready to bolt on!
05-17-2016, 09:07 AM | #8 |
just make sure to check the ball joints before you assemble anything
'68 C10 SWB '85 K30 Blazer |
05-17-2016, 09:30 AM | #9 |
you mean to make sure the factory ball joints fit? I was relieved all my '70 parts fit the CPP drop spindles. With the runaround you get from those guys I was nervous it was going to be a cluster.
05-17-2016, 10:59 AM | #10 |
Hmmm. I'm not sure how these would be considered cost effective. Convenient absolutely, but I just rebuilt my entire front end, upper bushings, lower bushings, upper and lower ball joints outer ties rods, and idler arm for less than $250 using all MOOG parts.(rock auto) It took me 6 hours. It won't take any more tools to perform vs replacing them with new units. (other than a grinder/ air hammer if you still have factory riveted top ball-joints)
I would suggest finding a salvage arm and rebuilding them if cost is a factor.
1970 GMC Stepside Short Gone...Factory 350 V8 Now...4.8L LS |
05-17-2016, 11:16 AM | #11 | |
Also how do you like your KYB shocks? I have the mono tube style and love them.
05-17-2016, 11:37 AM | #12 |
They seem to work well. They came with the ECE drop kit I bought.
Considering the rear shocks were still the originals from 1967... that was a nice improvement.
05-17-2016, 01:06 PM | #13 | |
If I was retired and had the time, I might be more interested to go the hard way but I want the downtime for this upgrade project minimal. The longer it is apart, the more stuff I find that I should do while it is apart and the more the project snowballs.
