Old 05-16-2016, 06:37 PM   #1
chrismoore701
chrismoore701's Avatar
Boosting antenna
Is there a way to boost the antenna in my 79? It is in the windshield. I installed a custom autosound and the reception is terrible.
Any ideas?
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 05-16-2016, 07:06 PM   #2
tucsonjwt
Re: Boosting antenna
I would check your connections. I have owned 3 squares with antennas in the windshield and all had good reception. I currently have a base model Alpine head unit and it has good reception in my 83 C20.
tucsonjwt is offline   Reply With Quote
Old 05-17-2016, 02:00 AM   #3
andrewmp6
Or worse case get a hidden car antenna theres many styles and brands.
Old 05-17-2016, 10:07 AM   #4
cadillac_al
I always thought the windshield antennas were the best. My old Clarion stereo has the best tuner in the business and always worked great in my Cutlass with windshield antenna. I put it in my Cadillac with fender antenna and the reception wasn't as good. I immediately determined that windshield antennas were better. I bought another cheap fender mount antenna and that was the same. I then went to the tried and true metal coat hanger sitting on the trans hump and that was slightly worse than a fender antenna but still very usable.
I would be curious how a basic coat hanger would compare to your antenna. If it's better, then there must be a problem with your antenna connection. My trucks just have cheapo radios in them so I haven't put them to the test in years trying to get those distant stations. I hope Custom Autosound doesn't use cheap tuners because I am close to buying one myself. Keep us posted if you find a solution.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 05-17-2016, 10:42 AM   #5
chrismoore701
It fades in and out real bad when I drive. I plan to try a piece of wire stuck in the back of the radio. I checked my connections and they are good. Would like to know if there is a way to check continuity
Chris
Chris
Old 05-17-2016, 11:06 AM   #6
tucsonjwt
I suppose you could check the continuity in the windshield antenna itself. I never heard of an antenna break inside of the windshield, but I suppose it is possible. As I recall, there are two wires under the button style cover at the windshield base. You can use a multimeter to check continuity on the two wire ends. You can check Youtube for some good instructions on how to check continuity and detect an open circuit if you are unclear on this.
Old 05-17-2016, 09:40 PM   #7
roger97338
roger97338's Avatar
I haven't looked through it, but here is a link to a Delco radio service book. It probably has something in it on testing and/or troubleshooting antennae problems.
https://onedrive.live.com/redir?resi...int=file%2cpdf
If that link doesn't work, you can find it with all the other tech manuals on that other Chevy pickup forum. (I'm not sure if it's cool to name drop or not.)
roger97338 is offline   Reply With Quote
Old 05-17-2016, 10:11 PM   #8
Jrgunn5150
They actually used to sell antenna boosters for these thing's. I recall my dad putting them in his truck and my mom's Grand Prix back in the 80's, have you checked Amazon?
J.R.
Link to Daryl's build, http://67-72chevytrucks.com/vboard/s...10#post8443010
Link to my Youtube channel with build info, https://www.youtube.com/thedrivewayengineer
Jrgunn5150 is offline   Reply With Quote
Old 05-18-2016, 05:28 PM   #9
chrismoore701
See link
Amazon.com: Actpe Audo Car Inline Antenna Radio... Amazon.com: Actpe Audo Car Inline Antenna Radio...
I have a power antenna lead from my painless harness. Worth a try
Chris
Old 05-18-2016, 11:10 PM   #10
chrismoore701
Do you think this is a good option
Chris
Old 05-19-2016, 01:15 PM   #11
tucsonjwt
I know that cell phone antenna boosters work well since I have used them in the past. The problem with the powered boosters is that they do get very hot.
I used a Wilson trucker antenna for a cell phone and it worked great on an old cell phone which I used inside my aluminum sided office trailer (think Faraday box, with zero reception.) I used the cell phone as a modem for an internet connection and it was excellent - 5 bars all the time. I would check the Wilson website to see what they might have for a radio. That trucker antenna is designed for a CB radio, but it probably has an adapter to work on a car radio, and would boost cell phone reception also if you got a two way connector - but then you would have to attach it to your exterior mirror - 10-4 rubber ducky.
I would still verify that your windshield antenna is intact first.
Trucker-Spring-Mount-Antenna/dp/B00L1UKRP6/ref=sr_1_4?ie=UTF8&qid=1463677647&sr=8-4&keywords=antenna+wilson
Old 05-19-2016, 02:34 PM   #12
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
It is the radio. I have one that is brand new and they get terrible reception.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 05-22-2016, 08:39 PM   #13
chrismoore701
Originally Posted by chrismoore701 View Post
Did not work. Maybe the antenna wire is broke between the radio and windshield. How do you test this?
Chris
