Old 05-18-2016, 12:58 PM   #1
IHutch5R
6 lug Disc brake conversion Q's
I'm looking at getting the 6 lug deluxe disc brake conversion/ front end rebuild kit from Brothers Trucks. First I'd like to know what yall think about that kit. Also, it says it doesn't fit with the stock wheels. Does that mean all 15" wheels? Any knowledge on this would be appreciated.
IHutch5R is offline   Reply With Quote
Old 05-18-2016, 01:38 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 6 lug Disc brake conversion Q's
you will need 71-87 4x4 steel wheels if you plan to run steel wheels.
The original 6-lug steel wheels from 1960-70 won't clear the disc brake caliper.
I suggest ECE for disc brake conversions.
They been doing this longer than anyone.
Check out www.earlyclassic.com
Keith
Convert to disc brakes.
Old 05-18-2016, 04:30 PM   #3
forestb
forestb's Avatar
They should work with other 15 inch wheel unless they are the cpp modular drop spindles (modular being the important word) than you will need a bigger wheel or less backspacing.
forestb is offline   Reply With Quote
Old 05-19-2016, 12:36 AM   #4
IHutch5R
What does "modular" mean?
Old 05-19-2016, 07:39 AM   #5
zach_carver
zach_carver's Avatar
I believe modual means that the spindles dont increase track width of the vehicle. Some spindles make the front tires wider than others, and the CPP keep the exact same width.
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 05-19-2016, 11:02 AM   #6
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Actually this is their spindle that does not have a cast in factory type caliper mount. They have a threaded location so you can mount different caliper brackets on, so you can run a stock brake package or a big brake kit like 13" or 14" rotors, 6 piston calipers, etc. Most all other brands of spindles only use a factory sized rotor and caliper.
I like them since they don't move the wheels out and if I ever want to upgrade to a big brake package, I don't have to change spindles.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 05-19-2016, 09:18 PM   #7
IHutch5R
http://www.classicperform.com/Store/...6370SWBK5S.htm
This is one of the kits I was looking at. Any input?
Old 04-30-2020, 09:26 AM   #8
Basketcase889
Basketcase889's Avatar
Looking to bump this thread instead of starting a new one..
Brothers had a sale on this month and their deluxe disc conversion was almost $250 dollars off.. Planned on going with CPP but this was a pretty good deal.
So then decided while I was placing a big order and the shipping was expensive, thought Id order the remainder of the 4/6 drop (since I got the drop spindles with the kit). So ordered springs, blocks, notch and shocks for now.
I wish ECE was still open as I would have went there... but they aren't.
Does anyone have experience with the Brothers brake kit or drop kits?
Edit: just realized this was in 60-66. my bad
1970 - Green LWB C10 - 250 I6/3OTT
1969 - Blue/White LWB C10 CST - 350/TH400
1950 - Original Patina 3600/S10
Basketcase889 is offline   Reply With Quote
Old 04-30-2020, 11:10 AM   #9
Chevy Fleetside
Chevy Fleetside's Avatar
If that kit was $800. You can try sourcing the parts yourself and save a little for your gas tank. It this link, I used all 75 chevy truck parts I had laying around. Had to buy the tie rod sleeves from CPP. Just a thought. http://www.67-72chevytrucks.com/vboa...isc+brake+swap
This is a picture of it just after a small rebuild. I have been running this for the last 3 years.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 04-30-2020, 11:14 AM   #10
Basketcase889
Thanks, looked into that option.. The brothers kit was $650 which I thought was pretty decent. Up here in Canada its hard to find used parts that are decent.
Old 04-30-2020, 11:27 PM   #11
Chevy Fleetside
Those are actually new spindles I have on the truck. They are just the 75 year model since that is what I used with the stock height spindles I had. I got the spindles at Summit Racing and they are CCP''s.
