Old 05-20-2016, 01:07 PM   #1
mikesacs
mikesacs's Avatar
Anyone use the automatic car wash?
Anyone use the automatic car wash with the spinning brushes with our trucks? I fear that it might damage my mirrors. I have the stock stainless mirrors with the triangle base.
mikesacs is offline   Reply With Quote
Old 05-20-2016, 01:40 PM   #2
Brandons63
Re: Anyone use the automatic car wash?
I would never take your truck through an auto wash that wasn't touch less!!! I would fear the brushes or pads would grab ahold of your mirror! I once took my '15 Ram 2500 through and it grabbed my side view and flipped it to the forward position.. It also broke off my antenna and bent my license plates.. My bad for not removing my antenna, but these things are harsh! May be fine for smaller cars or the sort... Never again!!
Brandons63 is offline   Reply With Quote
Old 05-20-2016, 01:46 PM   #3
mikesacs
mikesacs's Avatar
That's one negative response! I don't have an external antenna, but that would add to the concern.
Old 05-20-2016, 04:44 PM   #4
Clyde65
Clyde65's Avatar
I wouldn't. I value my truck too much to put it through that....
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-20-2016, 04:49 PM   #5
forestb
forestb's Avatar
I have a bigger problem here in Burbank CA. It is now illegal to wash your own car in Burbank because of the drought in California. I don't know what I am going to do after I get my truck back from paint.
forestb is offline   Reply With Quote
Old 05-20-2016, 10:20 PM   #6
racecougar
racecougar's Avatar
I wouldn't take a junk car through an automated car wash, much less one I actually cared about.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 05-20-2016, 10:29 PM   #7
zach_carver
zach_carver's Avatar
Ditto. I despise them things. Chemicals are so harsh to be touch free even. I'm out on that.
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 05-21-2016, 12:18 AM   #8
Captainfab
60-66 Nut
You will probably have to resort to something like this.
http://www.dwginternational.com/WebSite/DWG.shtml
I have a friend that is a distributor for their products. He swears by their products and uses them all the time. Here is his website.
http://www.marksdwg.com/
Old 05-21-2016, 08:28 AM   #9
Marla
Never...had my antenna torn off plus one wiper blade
Marla is offline   Reply With Quote
Old 05-21-2016, 08:32 AM   #10
Marla
If you used the bath water you can wash your vehicle...you need to take a couple of digital photos to prove it...our son did this and the neighbor freaked out...he showed them the photos and the guy said it was a great idea and immediately washed his car...after he took a bath...just saying...Marla
Old 05-21-2016, 08:33 AM   #11
Mike Wessinger
Mike Wessinger's Avatar
Never. Not on any of my cars, and even though my old truck's paint really is done for, I still wouldn't take it through one. As said above, too many chances of ripping something off. For my cars, I would be concerned I was running through right after some kid got back from mudding in his truck, and the brushes would be hiding all sorts of grit and scratch up my car. That may or may not happen, but I haven't seen the need to risk it either.
1965 Chevy C10 Stepside Shortbed--2012 370Z Base Gun Metallic--2020 Chevy Silverado RST Crew Cab
Mike Wessinger is offline   Reply With Quote
Old 05-21-2016, 10:17 AM   #12
Brandons63
I second the dry wash motion if you can't use water. We use a product called No-Wet on our helicopters and the stuff works surprisingly well I have to admit. U experiment with a lot of different cleaners in my profession trying to find the one that works the best, the fastest, and the cheapest. Top two degreasers-- purple power and aircraft extreme simple green (this stuff in truly amazing). I also like using acid on very soiled paint, chrome, and aluminum.. Phosphoric acid works great on stainless.. It's amazing how it eats the rust and other corrosion . You can see the before and after of the acid bath on my build thread. No scrubbing, spray on spray off. And between washes try some McGuires quick detailer.. The stuff in the red bottle. Not the new black one. Works well to keep the paint clean and from attracting the dirt. Little off topic but maybe someone finds it useful
http://67-72chevytrucks.com/vboard/s...t=Corvette+327
http://67-72chevytrucks.com/vboard/s...d.php?t=704329
Old 05-21-2016, 03:40 PM   #13
curvedglass
curvedglass's Avatar
I admit to it. We have one down the road from my work. Get corp discount too. They use a neoprene set of brushes that are softer than the normal nylon. I see black BMW's, Caddy's, Benz's come out looking fine. My well water is so hard that even after the biggest softener you can buy - it still leaves etching spots. So any way the car wash guy has to hold up the top roller brush when i go thru. the first time the brush got stuck on the sun visor over the windshield and they had to stop the line to come get me. Other than it works good. even a wheel brush for the white letters.
--Life looks better through a curved windshield--
curvedglass is offline   Reply With Quote
Old 05-21-2016, 07:27 PM   #14
forestb
forestb's Avatar
That is hilarious
