Old 05-22-2016, 04:25 PM   #1
chrismoore701
chrismoore701's Avatar
Bent hood
I have a 79 c10 with a bent hood. Freshly painted just did not catch the bow before I installed it. Thought about the lmc braces then all you guys said they could kill me. So I figure I better listen. What do you guys think about stress cuts along the inner structure. And then weld back after I get the bow out. Watching *****in rides and figure if they can do something similar. I can to
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 05-22-2016, 04:34 PM   #2
true74enduro
Re: Bent hood
How about some pictures
true74enduro is offline   Reply With Quote
Old 05-22-2016, 07:21 PM   #3
UKNOWME
UKNOWME's Avatar
Re: Bent hood
Kill you????? I installed those braces on my new hood after painting it to prevent from bending.
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 05-22-2016, 08:13 PM   #4
chrismoore701
Re: Bent hood
The location those braces go are right over the crumple zone you brace that and take a hit in the front the hood will go straight back instead of bending and shear the roof off and everything else in the way
Chris
Old 05-22-2016, 08:21 PM   #5
UKNOWME
UKNOWME's Avatar
Re: Bent hood
Wow, never thought about that. Interesting that they haven't been removed from the market. Hope I don't get in a crash.
1964 Chevy c10
Old 05-22-2016, 09:29 PM   #6
true74enduro
Re: Bent hood
Slight bends holes that are from the factory are a crush or bend zone. They are designed so that the damage shouldn't go into the cab and hurt or kill the occupants inside.
Old 05-22-2016, 10:12 PM   #7
UKNOWME
UKNOWME's Avatar
Re: Bent hood
Makes sense
1964 Chevy c10
Old 05-22-2016, 10:18 PM   #8
chrismoore701
Re: Bent hood
Here are a couple of pics. I don't think it will work because of the edge of the hood
Chris
Old 05-22-2016, 10:20 PM   #9
chrismoore701
Re: Bent hood
Pic of the bow. I think I have bad hinges as well
Chris
Old 05-22-2016, 10:21 PM   #10
chrismoore701
Re: Bent hood
Pic of bow after I pushed the hood down
Chris
Old 05-22-2016, 11:01 PM   #11
true74enduro
Re: Bent hood
Do you weld? That should be an easy fix base lines style lines flanges are key to keeping panels in line and sharpe.
Old 05-22-2016, 11:09 PM   #12
chrismoore701
Re: Bent hood
I do
Chris
Old 05-22-2016, 11:19 PM   #13
MountainGoat1966
Re: Bent hood
I am trying to avoid the bent hood syndrome on both of my squares by keeping the hood hinges, latch, etc all well lubed.
I have enough other things to spend time and money and labor on.
In dash stereo and new seats are more important.
"Off the grid and on the seven day weekend plan"
"One person cannot know everything, but between all of us, there isn't much we don't know."
MountainGoat1966 is offline   Reply With Quote
Old 05-23-2016, 12:27 AM   #14
nonstop
Re: Bent hood
And you said you were done.....
nonstop is offline   Reply With Quote
Old 05-23-2016, 01:01 PM   #15
Pontiac1976
Pontiac1976's Avatar
Re: Bent hood
Well that not to bad of a bent. (Keep your hood hinges lubed.) Get a 4x4 about 2 to2-1/2' long, have tear cloth, cotton cloth ( or both softest on the bottom) under the 4x4 put it dead center on the bend across it 2or 3 pounds sled med hits till it moved enough. Oh sand the edges & corners round so it does leave any marks from edges make sure flat to the hood when hitting. The Paint has to be pretty hard when you do this or it may put a flat mark on the paint. ( Then it up to you if you never rear end or get a really hard hit in the front. The Is bent it is stressed right now it will bend the next time it’s hit hard I might bend to much still go through cab a different way because it weaker now. 50 % chance life do badly hurt ( New hood would be the safes route, but it’s up to you how lucky are you what why you want to play with your chances. "DarkGreen" If you do try the hit There still a chance you might have to touch up the paint.
How Lucky Do You Feel Punk! love that Quote:
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 05-23-2016, 01:30 PM   #16
chrismoore701
Re: Bent hood
I have a Spare hood that needs some work. But trying to avoid repainting. I just finished the build. So may wait until the winter just in case I mess it up
Chris
Old 05-23-2016, 06:59 PM   #17
Gmc.guy
Gmc.guy's Avatar
Re: Bent hood
I prop the hood up and pull the springs off Then lube them and work hood up and down and lube again. Then pop springs back on. You can pull them down with 2 fingers after that Works well on trucks that have been sitting for a long time This truck got the "dam 6 cylinder" and hood slam I think before I got ahold of it Shame it's a perfect hood other than the bow NOS hoods are hard to find. I collected doors and fenders for it so far Body will be this winter on this one
-Cody
Gmc.guy is offline   Reply With Quote
Old 05-23-2016, 07:01 PM   #18
Gmc.guy
Gmc.guy's Avatar
Re: Bent hood
^^ check out the rusty/bent frame Finally found one to replace it
-Cody
Old 05-23-2016, 10:40 PM   #19
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Lightbulb Re: Bent hood
It's the spring's that are the problem on the early gen hood hinges they are way too strong it's not so much the hinge as long as the rivets are tight and there isn't a lot of rust between the links keep 'em lubed. you should be good.
I remember seeing something somewhere about weaker replacement spring's for this problem but I don't remember where cuz it really didn't pertain to my gen truck.
I had friend's that had these truck's back n the day and they just removed the springs all together and just used a prop rod. I know it don't look good but it beats the bowed up hood look.
Maybe think of trying to find a pressurized hood strut and play around mounting them to the hood with the old spring removed.
I did this on my harwood Cowl Induction hood.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 05-23-2016, 10:51 PM   #20
87 STEPPER
87 STEPPER's Avatar
Re: Bent hood
Here's a pic
Name:  87 stepper hood_shock_strut.jpg
If I can do this with a glass hood it should be able to be done with a steel hood.
I have a steel cowl ind hood and I hope this strut will be strong enough to hold it up.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
Old 05-24-2016, 07:13 AM   #21
cadillac_al
Re: Bent hood
If you can't close your hood with one hand then you have a hinge problem. If you guys are bending hoods with one hand then you have above average strength. I guess the moral of the thread is to just oil your hinges every year or two.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 05-24-2016, 07:33 AM   #22
chrismoore701
Re: Bent hood
The damage to the hood was before I installed it. I did not notice it until it was too late. The hinges are lubed. I know need to know how to fix the bow
if it is possible
Chris
Old 05-24-2016, 08:09 AM   #23
WAM Rods
WAM Rods's Avatar
Re: Bent hood
Originally Posted by 87 STEPPER View Post
Here's a pic
Attachment 1536029
We make a hood strut kit for the 81 & up style trucks although the OP was asking about the 73-80 style which is completely different.
WAM Rods
More info here
WAM Rods is offline   Reply With Quote
Old 05-24-2016, 09:37 AM   #24
Firebirdjones
Re: Bent hood
Fixing the bow completely probably isn't going to happen, and playing with it enough will eventually mess up the paint job in some way shape or form.
Best fix is to buy a new hood (they aren't expensive) and paint it.
Firebirdjones is offline   Reply With Quote
Old 05-24-2016, 10:36 AM   #25
Front Range
Front Range's Avatar
Re: Bent hood
On the Harwood Site they recommend a #210 spring for the Harwood brand hood. Summit sells the 210 spring for 40-ish bucks.
I read a thread somewhere else were a member recommended a prop rod with low tension springs. Apparently with any kind of breeze the hood would come down and swat you if the spring would hold it up at all. Never done it so I can't confirm the validity of that statement. I'm guessing somebody will have to be a 40 dollar guinea pig for an accurate answer.
Folks that throw dirt on you aren't always trying to hurt you, and folks that pull you out of a jam aren't always trying to help you.
Front Range is offline   Reply With Quote
