Old 05-25-2016, 06:47 PM   #26
OUbesto
OUbesto's Avatar
Re: Horn doesn't work!
yah, I need to get a puller. I've read on the forum that some recommend from Harbor Freight is pretty cheap. Thanks so much for your help. I will certainly report back once I get wheel off and take a peek at the cam and switch etc.. Thanks again!
1970 C-10 CST, LWB, 402/400, A/C
OUbesto is offline   Reply With Quote
Old 05-25-2016, 06:59 PM   #27
LockDoc
The Older Generation
LockDoc's Avatar
No problem. Yes, let us know what you find. Be sure and check the spring inside the cancelling cam tower, it may be broken. To get it out you have to turn the small Red plastic piece inside the top of the tower 1/4 turn but I don't remember which way....
LockDoc
Leon
Old 05-26-2016, 01:33 PM   #28
snipescastle2
snipescastle2's Avatar
Talking Re: Horn doesn't work!
there is a wire that is inside the rag joint (joins the steering shaft to the steering gear box) if that wire is broken, that may also cause you to have an incomplete circuit......
HTH,
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline   Reply With Quote
Old 05-26-2016, 04:01 PM   #29
OUbesto
OUbesto's Avatar
Hey Ben, I looked everywhere down by the gear box but I don't see any wires. is it possible to send me picture or provide more details as to where I might look for it? Thanks so much!
Old 05-26-2016, 07:48 PM   #30
franken
Seems like you grounded the pin and the horn sounded at one point, but its not working now?
The horn button provides a ground to the horn relay via the flat round spring disk when you press the horn button. That spring also makes the horn button pop back up. The coil spring under the steering wheel should make the pin spring up and keeps in in contact with the cancelling cam and the metal bits above.
The steering column needs to be grounded or the horn relay won't get a ground...
Its been a few years since I fixed mine but as I recall the disk spring should be oriented like an upside down bowl.
Old 05-26-2016, 07:58 PM   #31
OUbesto
OUbesto's Avatar
Franken,
I did previously say that I grounded the pin and the horn sounded, however when I revisited the troubleshooting, I noticed that when I attempted to touch the pin with the ground wire, I inadvertently was also touching the base plate and I believe that what was causing it to sound the horn. So I placed some tape on the base around the pin and this time I could not get the horn to sound either when the pin was fully depressed or fully extended outward. If I touch the grounded wire anywhere on the steering rod, nut, base plate I get immediate horn sound so I know steering column is a good ground. I believe my next step is to pull off the wheel and see what's happening under there.
Old 05-27-2016, 12:12 AM   #32
66clow
66clow's Avatar
Here a technique I have use to remove the steering wheel without a puller.
https://youtu.be/l7tEaWUqtEY
66clow is offline   Reply With Quote
Old 05-27-2016, 01:37 AM   #33
El Dorado Jim
curious as to what you find out..
El Dorado Jim is offline   Reply With Quote
Old 05-27-2016, 08:27 AM   #34
spidermn
spidermn's Avatar
Who needs a horn when you have a big ol loud motor!
Go BIG or GO home!!
1970 Custom Chevy C10 / 350 bored .30 over / 5.5/7 drop on 20" boss 338
spidermn is offline   Reply With Quote
Old 05-27-2016, 09:56 AM   #35
LockDoc
LockDoc's Avatar
It's hard to use that when you are off the gas and hard on the brakes.....
LockDoc
Leon
Old 05-27-2016, 04:24 PM   #36
snipescastle2
I have seen many rag joints without these ground connections in them before,
But I know mine has it and my horn works.... Here's a few pics.....
Old 05-27-2016, 04:53 PM   #37
snipescastle2
sorry, images didn't upload from my phone....here you go.....
Ben
Old 05-27-2016, 05:22 PM   #38
OUbesto
OUbesto's Avatar
Hey Ben,
Perfect...now I know what I'm looking for! I'll report back next week (taking weekend off!!)
Old 05-27-2016, 08:04 PM   #39
66clow
66clow's Avatar
Hey Ben,
No the suspense is killing us, well me because I need a working horn also
Old 06-02-2016, 10:40 PM   #40
OUbesto
OUbesto's Avatar
I think I'm getting closer to a solution. I removed steering wheel and tested for good ground on the copper pin in the cancelling cam. I pushed down on the copper pin to be sure it was fully depressed but still no horn sound. But when I touched my relay wire to steering bolt, I get horn sound. (I still have a jumper wire hooked up to my relay.) So next I removed cancelling cam part so I could see underside of cam and where the copper pin bottoms out. The copper pin is designed to make contact with a very small metal plate ( approx 1/8" wide) and that plate is connected to a black wire that is part of the steering wheel wiring harness. I tested horn again by touching my horn relay wire directly to the small metal plate (this would bypass the copper pin) so I could eliminate the copper pin and black plastic contact. Still no horn sound. So next step was to test continuity of black wire attached the small contact plate and the other end of the steering wheel harness located at the bottom of the steering column near the firewall. Tested ok. So it appears I do not have a good ground (black wire) feeding the steering column wire harness. I tried to follow the black wire feeding the harness but it goes into a larger main harness under the driver side dash with many other wires that ultimately leads into fuse panel.
Hopefully this isn't too confusing!
Do you think I can just tap into the "black" wire from the steering wire harness and make a new connection to a local ground?
Old 06-03-2016, 12:31 PM   #41
OUbesto
OUbesto's Avatar
New update....I now have a good ground up to the copper pin in the white plastic directional mechanism. That's the god news! However, after I place the black round plastic cancelling cam and tighten up the nut, I no longer get a ground when testing the light metal pin that comes thru the steering wheel base plate. I reinstalled the steering shaft spring underneath the cancelling cam (which was the way it was originally installed by PO image #1). It seems to me that when the coil spring is installed below the cancelling cam, it does not tighten down far enough to make contact with the copper pin and the underside of the cancelling cam to make complete ground. If I remove spring from the underside of the cam (image #2) and slide cam as far as it will slide down the shaft, I get a good ground contact at the tip of the top metal pin. Anyone know if the spring should be installed first, before the cancelling cam (image #1)? Or should it be installed after, or on top of the cam between the steering wheel?
Old 06-03-2016, 12:39 PM   #42
OUbesto
OUbesto's Avatar
I for got to attach steering wheel assembly from shop manual that does NOT even show a spring on either side of the cancelling cam (#31). ??????
Old 06-03-2016, 01:09 PM   #43
OUbesto
OUbesto's Avatar
Just assembled without the steering column spring and......horn blows continuously! Ready to throw in the towel!!
Old 06-03-2016, 02:13 PM   #44
66clow
66clow's Avatar
Keep the photos coming I'm sorry but your taking the pain for me before I dig in fixing mine. I'm not starting until you fix yours. I just went through this craziness with my lights trying to get them to work. Little stuff like this makes you want to up and sell the truck I've been there. You spend way too much time on one little problem, and then it turns out to be some little simple fix.
Old 06-03-2016, 07:21 PM   #45
haycatcher
Spring goes in first then cam.
haycatcher is offline   Reply With Quote
Old 06-03-2016, 07:31 PM   #46
OUbesto
OUbesto's Avatar
Guess that's why it was installed that way originally. Anyone have a clue why cam won't tighten down far enough for the underside of the cam to make contact with the copper pin in the directional mechanism? Should I try tightening down harder on the nut even though I am already tightening it down @ spec of 50 ft lbs.
Old 06-04-2016, 12:18 AM   #47
LockDoc
LockDoc's Avatar
Is your column a tilt? It doesn't look like it but it Looks to me like the cancelling cam and spring in the above pictures are for a tilt column. A non tilt cancelling cam would be White and would not use the spring.
LockDoc
Leon
Old 06-04-2016, 07:20 AM   #48
OUbesto
OUbesto's Avatar
It is a tilt wheel. I read somewhere last night that tilt wasn't available until 71, so I'm thinking PO upgraded?
Old 06-04-2016, 09:09 AM   #49
haycatcher
I would look at copper pin in turn signal switch as it seems short in the pictures you provided. Might need to replace that?
Old 06-04-2016, 09:55 AM   #50
OUbesto
OUbesto's Avatar
Cool Re: Horn doesn't work!
Next stop...LMC for a new $6 copper pin! I'll report back
