Old 05-26-2016, 12:41 PM   #1
1981_c10
1981_c10's Avatar
400 SBC Head Choice????
Hey y'all, I have a 1962 c10 I purchased a few weeks back that came with a 70-80 model 400 sbc. Per that block casting number, this is the 190 hp engine. I am wanting to change the heads. Don't want to spend a crazy amount. I have some double hump heads that I can have machined...but I have been seeing guys put vortec heads on it?
Advice? Opinions? What which way should I go?
Builds:
1962 C10 Recreating Dad's High School Truck
1981 C10
1981_c10 is offline   Reply With Quote
Old 05-26-2016, 02:36 PM   #2
duallyjams
duallyjams's Avatar
Re: 400 SBC Head Choice????
just make sure you drill the steam holes in the head for the 400, the 400 requires these because of being a siamese bore block
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 05-26-2016, 02:38 PM   #3
1981_c10
1981_c10's Avatar
I think the current plan is to use the double hump heads and drill the steam holes like you are saying. I just didn't know about using the vortec heads like I keep seeing. Hot rod mag put out an article about using them a while back.
Builds:
1981 C10
Old 05-26-2016, 02:42 PM   #4
1961apacheC10
My understanding is you have to be careful using vortec heads depending on the type of piston you can get way too much compression because of the smaller combustion chamber.
1961apacheC10 is offline   Reply With Quote
Old 05-26-2016, 04:13 PM   #5
1981_c10
1981_c10's Avatar
For sure, thanks for the heads up!
Builds:
1981 C10
Old 05-26-2016, 08:21 PM   #6
lumpy63
lumpy63's Avatar
You can run the double hump heads on you're 400 you have to drill the steam holes as mentioned , but be aware they have 64cc chambers and on a 400 this raises the compression ratio significantly due to the bore and stroke of the 400.I have the same set up on my daily driver 56 and MUST run premium fuel.Also take into account the cost of machine work because you really should install hardened exhaust seats for unleaded fuel. 400s are awesome engines at the moment I have 3 that are driven often.
lumpy63 is offline   Reply With Quote
Old 05-26-2016, 11:07 PM   #7
LVPhotos
LVPhotos's Avatar
Is this a true no rebuild? Mine came out of trash can for $100 and heads of my 79 k10. 1976 Caprice block. KEITH BLACK flat top at 9.5 I think more. At 400 hp with rv cam Z28 off shelf cam. Weekend cam puts it at 500 and as the shop runs same set up... 100 shot N0X at 600. Torque monster.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 05-26-2016, 11:22 PM   #8
Captainfab
60-66 Nut
You can install heads onto a small block 400 that have 64cc chambers as long as the pistons are stock type dished pistons. Whether you will have to run premium gas or not depends on several factors, one being the cam used. Your 'double hump' heads will work, but the L31 Vortecs are better heads. Those double humps and the L31 Vortec heads both have aprox 64cc combustion chambers.
Here is a thread with lots of info to give you some ideas.
http://www.67-72chevytrucks.com/vboa...d.php?t=612016
Old 05-27-2016, 02:48 PM   #9
lumpy63
lumpy63's Avatar
Yes the vortec heads are a great piece but be aware you also must run a vortec type intake manifold and guided rocker arms all adding to the cost.
