05-27-2016, 10:02 PM | #1 |
Active Member
72 blazer lq9 swap
Need a recommendation on a wiring system 4L80 to LQ 9 4 wheel drive . Any ideas?? thanks
05-27-2016, 10:48 PM | #2 |
Re: 72 blazer lq9 swap
You'll probably get a lot of differing answers on this..but I used PSI and was well pleased.
05-29-2016, 09:54 AM | #3 |
I have used Howell Engine Development for my harnesses and programing
Works for me !
05-29-2016, 12:37 PM | #4 |
I would use a sponsoring vendor if possible !
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
06-01-2016, 10:03 AM | #5 |
tons of diagram info on LT1swap.com
get a stock harness and modify it on your own you can use the original fuse box with relays or make it completely stand a lone
1973 K5, full vert, 6" BDS lift, 35 Mickey T MTs 1984 K10, 8" lift on 35s 2004 3/4 4wd, 33s Toyo Mts, Long Tube headers, 3K multidisk 80e, tons of miles 2011 Yukon XL | Bone stock 2013 Audi Q5 |
06-03-2016, 05:18 PM | #6 |
06-04-2016, 08:21 AM | #7 | |
If you want to run the engine and the electric . . . the 700 will not work. It's all manual your option is to find a 4L60e or keep the 700R4 and run a cable to the throttle body for the kick down.
06-04-2016, 11:02 AM | #8 | |
