Old 05-28-2016, 04:25 PM   #1
BoneSaw
BoneSaw's Avatar
Help with brake line sizes for 68 k2500 dana 60 swap
hey guys,
I swapped out my front dana 44 for a 60, and got new soft hoses to go from caliper to frame. The threads dont match up to the hard lines. I thought the hard lines were 3/16 but i guess not. Has anyone run into this? what size are those hardlines? Or are the banjo bolt at the juntion block and passenger line nut 3/16 with different threads? whats my best course of action? thanks in advance for any info!
Mike
Paul "Mike" Tzareff
BoneSaw is offline   Reply With Quote
Old 05-28-2016, 04:31 PM   #2
msgross
msgross's Avatar
Re: Help with brake line sizes for 68 k2500 dana 60 swap
I know that the banjo bolt went from standard to metric in the early 80's (maybe?). Wouldn't be surprised if the other end changed as well.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 05-28-2016, 04:43 PM   #3
BoneSaw
BoneSaw's Avatar
That makes sense, because im pretty sure the line is 3/16 and the bolts are almost the same size. I wonder if i can get a t block that comes in standard takes a metric 10mm banjo and comes out metric and get a metric line to run to the passenger side.
Paul "Mike" Tzareff
Old 05-28-2016, 05:31 PM   #4
msgross
msgross's Avatar
they do make adapters, I'd hit NAPA to check
The Garage:
Old 05-29-2016, 01:53 AM   #5
mike16
yes they do. and are about 4 bucks. I ran into the same problem putting a 71 12 bolt rear under a 65 lemans. A good parts guy will sort you out in a minute.
Oh, your taking about the front axle...I was talking about the rear axle.
Have you tried inline tube or classic tube.
mike16 is offline   Reply With Quote
