Old 05-29-2016, 03:05 PM   #1
Paul Y
What is the correct way to remove LS wiring plugs?
Afternoon All,
So, threw my 5.3 into the recently vacated hole left by my small block.
All just balanced in there at the moment as still need a gearbox.
However, want to take the opportunity to clean, paint the engine and route the wires properly. Question is, what is the correct way to remove the electrical plugs?
Started trying to pull the injector harness off and I felt as if I was going to break something, well I am a bit of a Neanderthal when it comes to stuck stuff.
Probably a really basic question but if you could advise I would appreciate it.
Many thanks,
P.
Woody's Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=658621
If it goes wrong, I blame the Internet...
Paul Y is offline   Reply With Quote
Old 05-29-2016, 04:57 PM   #2
mongocanfly
mongocanfly's Avatar
Re: What is the correct way to remove LS wiring plugs?
My injector plugs have a little tab (see pic) you have to press to release the catch..all the connectors in my harness have to be mashed or spread to release..
Old 05-29-2016, 05:11 PM   #3
68c10airstream
68c10airstream's Avatar
Some connectors on various brands will have a release tab cover to make it an additional item to lift up/remove to allow the tab to then be depressed/lifted up to remove the connector. Auto makers want that connector to stay latched in place, think of the consequences of say a crank sensor comes unplugged?? Vehicle dies and car gets "T-BONED"!! A liability issue for sure.
68c10airstream is offline   Reply With Quote
Old 05-30-2016, 04:38 AM   #4
Paul Y
Thank you.
I will spend a little more time today looking at how it all comes unhooked, some days it is best to walk away than continue and yesterday was that day!
P.
Woody's Build -
