Old 05-31-2016, 10:07 PM   #1
vetnat
non '66 back up lights for stepside?
Hi. I was wondering if any one has the optional back up lights on their '60 to '65 stepside? I would love to find the rubber gasket to mount back up lights to a regular fender. Are these as rare as unicorns?
1961 GMC half ton, short step, Canadian model. Just starting work on it.
vetnat is offline   Reply With Quote
Old 06-01-2016, 04:26 AM   #2
Tazimafied
Re: non '66 back up lights for stepside?
LMC has them. I'm sure others have them as well. Light housings are a pretty commonly reproduced item.
http://www.lmctruck.com/icatalog/CBE/full.aspx?page=116
Tazimafied is offline   Reply With Quote
Old 06-01-2016, 05:32 AM   #3
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
I think he means the tapered rubber wedges.
Old 06-01-2016, 11:17 PM   #4
vetnat
Yeah, the "mounting wedges" are what I mean. Anyone have them installed on their truck? I'd like to see pictures.
Old 06-02-2016, 12:14 AM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
I used NOS Unity back up lights on my 1960 GMC stepside. They have smaller diameter lights with the rubber alignment discs. Mine can be seen on post 87, half way down on page 4 of build thread:
http://67-72chevytrucks.com/vboard/s...=444502&page=4
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 06-02-2016, 01:07 AM   #6
vetnat
Love the truck, and the lights! For some strange reason, I really want the fender mounted back up lights. I think because I think they are rare. And my fenders are already cut up, with old after market tail lights mounted on the fenders, not on the brackets.
Old 06-02-2016, 03:21 PM   #7
Tazimafied
MarkeB,
Love the '59 Caddie lights. Looks great with the dual headlights. Completes the package.
Vetnat,
I have had success before using exhaust tubing and sheet metal. Wish I had a pic. Cut one end at an angle to match the fender, use a grinder to match the contour and weld a piece of sheet on it to mount the light. Or you could do it in reverse and cut a hole in the fender to match the diameter of the tube, weld it in straight and level, cut and grind the excess flat with the contour of the fender, weld sheet to the back of the tube and mount your light. Viola, frenched reverse lights! You just have to find the right diameter of tube to match the light.
Old 06-02-2016, 09:29 PM   #8
vetnat
Awesome tip! Thank you! If you ever find pictures, I'd like to see them.
Old 06-02-2016, 11:25 PM   #9
luvbowties
luvbowties's Avatar
Smile Re: non '66 back up lights for stepside?
Sounds like you are not convinced about mark's lights. I think markeb01 has what you are really looking for--either 'some' lights to make, say, a 1965 look like a 1966 as far as backup lights are concerned or else ARE the 1966 lights complete with the wedges to adapt. 1966 was the 1st year to have the 'tapered hole' in the fender to accept the fender-mounted bkup lights. Markeb01's light-wedges adapt the 66-type to 65 and earlier fenders.
Hope this may clear up some confusion,
Sam
luvbowties is offline   Reply With Quote
