![]() Join Date: Oct 2012
Mustang 2 crossmember
Hello. Has anyone ever tried to install a mustang 2 crossmember on a 67-72 Chevy truck? Every ifs that I have looked @ cost about $4000.00. No one seems to make a crossmember that you can use with the rest of your stock parts until your budget allows you to upgrade. If any vendor is listening, I want a 10% commission. I'm Mainly referring to the kind speedway sells. And is something like that is possible how was it done. Thanks in advance fellow board members.
Re: Mustang 2 crossmember
why would one remove an IFS to install different IFS that brings no real benefit to the chassis?
Knowing Clark I would guess to get lower and have rack and pinion for less cost than the usual aftermarket set ups.
Here is a thread that is related. http://67-72chevytrucks.com/vboard/s...d.php?t=562157 Seems like it would be less fab work to section a crossmember and buy the No Limit Rack.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
David, you have won the grand prize."Vanna White, give David 2 cigars and a bottle of our best scotch. I am searching for those final 2 inches. Thanks for the link David. It's time to get my read on.
Have you looked at scotts http://www.scottshotrods.com/1963-87...k-bolt-in-ifs/ his cheapest option is a lil under 3k,Or you can get a stage one dropmember with air bags or coilovers fully dressed about 3k if i remember right,But take a look yoursefl http://pbfab.com/
Thanks for your reply andrewmp6.I'll Check it out.
