Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 06-02-2016, 08:24 AM   #76
wannabefastcrf
Re: The Blazer Train
Long time since I updated this but still working on the blazer. My harness was finally returned and I will spare everyone the details but I had expected a 3-4 week turn around and got my stuff back after about 13 weeks and a few frustrated emails. My ecu was suppose to be tuned for my cam (I confirmed he could get it close before I bought it) and when it came time to flash it I was told he didn't want to do it. The product I received doesn't come with labels just a diagram. In all I got it to work. Not sure if I would do it again.
wannabefastcrf is offline   Reply With Quote
Old 06-02-2016, 08:30 AM   #77
wannabefastcrf
Memorial Day weekend I got a little help and was able to put in some time on the project. Got the body back on the frame. Air box placed. Ecu mounted. And a good jump on harness integration. Big thanks to ls1nova for some direction when I hit road blocks.
Old 07-12-2016, 01:27 PM   #78
wannabefastcrf
I got the blazer all finished up for this summer finally just in time for the dunes.
Old 07-12-2016, 01:40 PM   #79
lowrodderchev
lowrodderchev's Avatar
looks great man good job
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 07-12-2016, 02:08 PM   #80
72ironmike
72ironmike's Avatar
Really looks nice !
72ironmike is online now   Reply With Quote
Old 07-12-2016, 02:39 PM   #81
lks dcvn
lks dcvn's Avatar
Looks great - where in NW Ohio are you from? Looking to go with a LS swap down the road and might hit you up if I have questions.
lks dcvn is offline   Reply With Quote
Old 07-12-2016, 03:33 PM   #82
dennis7222
dennis7222's Avatar
Nice work, I have a 72 Chevy C10 pickup that needs work on the front passenger side of the cab. The rest of the body is cherry. Would you be interested in doing it?
dennis7222 is offline   Reply With Quote
Old 07-12-2016, 04:01 PM   #83
preciador6
Nice did you use the purple,Pink wire coming out the original fuse box? also can i get part # for the headers please
preciador6 is offline   Reply With Quote
Old 07-12-2016, 08:54 PM   #84
wannabefastcrf
I'm from wauseon
Old 07-12-2016, 09:07 PM   #85
wannabefastcrf
I used these headers
http://www.speed-engineering.com/fea...c10-truck.html
I used the purple wire for the started like it was originally. I didn't use the hei wire bc it was still the resistor wire. I ran new constant and key power wires.
Old 07-12-2016, 09:09 PM   #86
wannabefastcrf
Thanks but no thanks I have way to many projects of my own.
Old 07-13-2016, 11:11 AM   #87
preciador6
Should i run some new key power wires from the fuse box?
Old 07-13-2016, 04:36 PM   #88
Chulisohombre
Chulisohombre's Avatar
There is a spot on the stock fuse box for ignition on power. That's what I used for my hei unit. Just takes a blade connector and I used a 8 guage wire I believe. Been going like that ten years now.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 07-13-2016, 04:53 PM   #89
preciador6
That would be the thin pink wire that is used to power up the dist.
Old 07-13-2016, 05:55 PM   #90
Chulisohombre
I ran my own wire from there to the distributor through the firewall. I melted that fusable link pretty quick On the stock wire to the dizzy when I first ran my hei.
Old 07-13-2016, 06:13 PM   #91
preciador6
Ok....that pink wire gets hot quick thats why i wanted to know how everyone else hooks up there LS engine to the key power/fusebox
Old 07-13-2016, 07:06 PM   #92
wannabefastcrf
I would use a meter to check battery voltage then check the wire to make sure it's keyed power and that your getting enough volts. It might be ok.
Old 07-13-2016, 08:25 PM   #93
preciador6
Ok thanks guys.
