Old 06-04-2016, 11:54 PM   #1
The Swed
The Swed's Avatar
Bouncing Hood
At high speeds my hood bounces a lot in the middle... is there a fix for this?
Thanks for the help
1970 C20 350/TH350, LB
God Bless our Troops
The Swed is offline   Reply With Quote
Old 06-05-2016, 12:29 AM   #2
Lou Boffa
Lou Boffa's Avatar
Re: Bouncing Hood
I had the same problem. I replaced the deteriorated foam padding between the hood braces and the hood skin and I added an extra brace across the middle. Tightened it up.
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline   Reply With Quote
Old 06-05-2016, 12:44 AM   #3
The Swed
The Swed's Avatar
Re: Bouncing Hood
Outstanding! Thanks
Old 06-05-2016, 03:29 PM   #4
Jonlopes
Re: Bouncing Hood
I would love to get a little more info on the brace. What did you use, how did you attach it? Thanks!
1971 Cheyenne Big Block Longhorn
Jonlopes is offline   Reply With Quote
Old 06-06-2016, 03:49 PM   #5
The Swed
The Swed's Avatar
Re: Bouncing Hood
So would I! I have a few ideas but it would be great to know what and how...
Old 06-06-2016, 08:56 PM   #6
Stu Pidd
Re: Bouncing Hood
I went to the Chevy truck aisle at Home Depot and got a 1/2" x 1/2" x 36" square tube. Squirted satin black with a rattle can and stuck it under the hood's center ridge. Took 90% of the bounce out. Nobody has ever noticed it there.
Stu Pidd is offline   Reply With Quote
Old 06-07-2016, 09:49 PM   #7
Lou Boffa
Lou Boffa's Avatar
Re: Bouncing Hood
I used angle steel bar, cut one side section on both ends to slip under the hood brace, between the brace and the padding. Its a tight fil on my truck so no chance of it moving. Also you can make the cut at a slight angle and push the piece back to where it fits tightly against the edge of the brace.
Old 06-09-2016, 10:52 AM   #8
snipescastle2
snipescastle2's Avatar
Talking Re: Bouncing Hood
I used some sponge rubber gasket material from my work, it's 1/2" thick and I had to " shoe horn" it in between the hood skin and the bracing, but it significantly reduced the "Oil Can" vibration/bounce of the sheet metal, and I have a pretty lumpy solid lifter cam in mine.....I'll snap a few pictures once I get home this evening.
Have a good one!
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline   Reply With Quote
