Old 06-05-2016, 05:31 PM   #876
chad64chevy
chad64chevy's Avatar
Re: MY build thread...
got any side pics of the truck with the new rims/ and what size tires you running with them
chad64chevy is offline   Reply With Quote
Old 06-05-2016, 05:37 PM   #877
shortbed70
shortbed70's Avatar
20x8.5 245/35/20
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 06-05-2016, 06:47 PM   #878
shortbed70
shortbed70's Avatar
So far my truck has met every challange I've thrown at it. Street the first few years, then raced last year and now turning back to the street cruiser... Going to start looking into an LS swap for more drivability for the wife to take over the rains on this one!!
Troy
Big Red Dog build
Old 06-13-2016, 05:06 AM   #879
65 wonton
Sigh. If you could only find a nice red to paint it.
Otherwise, that's a dang fine looking truck.
Dave.
65 wonton is offline   Reply With Quote
Old 06-13-2016, 08:10 AM   #880
shortbed70
shortbed70's Avatar
Dave.
Yea I've got one picked out but now have to fix the motor lol... How's Big red doin?
Troy
Big Red Dog build
Old 06-14-2016, 06:32 PM   #881
chad64chevy
ls motor swap is in my future as well!
Old 07-15-2016, 04:48 PM   #882
shortbed70
shortbed70's Avatar
Well had a few set backs! Cam went flat (lost number 5 intake lobe and lifter) so tore it all down cleaned things up, installed a new cam and lifters with a split duration/lift cam to take advantage of the vortec head design so hopefully that will help be alittle more street freindly! So now full of Brad Penn oil and ready to get some miles on it!
Troy
Big Red Dog build
Old 05-13-2018, 12:39 AM   #883
shortbed70
shortbed70's Avatar
Well after lots of thought I think I’m going to swap in a small port bbc into the truck and make it more of a street cruiser with better manners on the street so the wife can drive it. The small block is alittle rowdy and temperamental! So my question is has anyone ran chevelle/camaro long tubes on their bbc swap with pics? I’m also thinking of staying around 10-1 with iron heads on the big block and a decent small roller for reliability. Any thoughts, opinions gear ratio etc. I’ll be running a built 700r 4.
Troy
Big Red Dog build
Old 05-13-2018, 12:44 AM   #884
Captainfab
60-66 Nut
Here's a thread on the headers.
http://www.67-72chevytrucks.com/vboa...velle+longtube
Depending on your rear tire size, with the OD trans I would run a 3.42 or 3.73 gear.
Old 12-31-2018, 01:57 PM   #885
shortbed70
shortbed70's Avatar
Disc swap done finally better brakes!!! BBC got file 13.. Onto bigger wheels and tires next... I’m thinking 315 will look nice on the back!
Troy
Big Red Dog build
Old 01-01-2019, 06:06 PM   #886
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Lookin' good man!
You should be able to hang those tires on that thing with the right wheel offset.
I have 315/35's inside of my bedwall with widened tubs & custom offset...Just in case I ever wanted to go lower, I wouldn't need to buy different wheels.
Modges'66 is offline   Reply With Quote
Old 01-03-2019, 08:51 AM   #887
shortbed70
shortbed70's Avatar
Thanks. They would fit but I wanted more dish so most likely will narrow the rear a few inches to get there.
Troy
Big Red Dog build
Old 12-19-2020, 09:26 AM   #888
The Rocknrod
Moderator
The Rocknrod's Avatar
Are you still using the same rear sway bar? How's it working out?
