Old 06-06-2016, 01:42 AM   #701
62stepside longbox
62stepside longbox's Avatar
Re: A 15 year old's project. Rusty 62 stepside
Here is some progress from the weekend. I decided to build a short throw shifter for the t5. First thing I did was drive the pin out of the hole and drilled a new hole exactly 1" above to move the pivot point up 1". Here's a pic with the pin in the newly drilled hole
62stepside longbox is offline   Reply With Quote
Old 06-06-2016, 01:50 AM   #702
62stepside longbox
Then I built a spacer plate out of some 3/16 plate I had laying around. It is exactly 1" thick to offset the amount I moved the pivot point by. This was very time consuming to cut, use the hole saw slowly and weld the two together. It would have been much faster to use aluminum but this is what I had and I made it work. Now all I need are some bolts that are 1" longer and it'll be done
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
Old 06-07-2016, 11:32 PM   #703
62stepside longbox
Progress has been slow lately due to the heat, but this evening I got all the bodywork on the rear drivers side of the cab all wrapped and sprayed it with some old paint to keep the surface rust off and so I could see my results.
Old 06-07-2016, 11:36 PM   #704
62stepside longbox
I'm pretty satisfied with the metalwork and bodywork that I have done on this corner, this is what it looked like when I bought it. It had a very large dent/crease and the door was sticking out past the rest of the cab by at least a 1/4"
Old 06-07-2016, 11:38 PM   #705
62stepside longbox
And this is how perfectly flush the door is now, closes with the push of a finger as well
Old 06-08-2016, 12:52 AM   #706
60chevyjim
60chevyjim's Avatar
your doing some nice work there .
I want to work on my 65 C-10 but
I'm still building my friends 65 C-10 for him , I'm doing the cab for his now.
it's on a cart on it's back I am getting ready to prime the roof this week ,
it's all clean bare metal with all the bodywork done .
60chevyjim is offline   Reply With Quote
Old 06-08-2016, 02:13 AM   #707
Grizz1963
Grizz1963's Avatar
This is certainly a Rock n Roll build, you just keep on progressing.
Good job on the cab side.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 06-08-2016, 05:11 AM   #708
You done good son!
Old 06-08-2016, 11:07 AM   #709
62stepside longbox
Thanks Jim, it sounds like you may have OCD (obsessive c10 disorder). Some of the symptoms include having too many projects, not enough money and or time.
Thanks rian, only a couple more weeks of school so I can start to get some real work done. I'll keep rocking and rolling for sure
You done good son!
Thanks bill. Good to hear from you, it's been awhile.
Old 06-08-2016, 12:10 PM   #710
Johnny_Lamebridge
Johnny_Lamebridge's Avatar
I think you'll like the shorter shifter throw... and nice job fixing that big dent.
My 63 C10 SWB Fleetside (converted to BBW):
http://67-72chevytrucks.com/vboard/s...58#post6851558
@johnny_lamebridge on Instagram
Johnny_Lamebridge is offline   Reply With Quote
Old 06-08-2016, 02:31 PM   #711
TJ's Chevy
TJ's Chevy's Avatar
Looks great! Nice job!
Old 06-08-2016, 06:41 PM   #712
62stepside longbox
Thanks Johnny, I think It'll be a big improvement from the stock shifter.
Thanks bud
Old 06-08-2016, 06:43 PM   #713
Originally Posted by 62stepside longbox View Post
...........................Thanks bill. Good to hear from you, it's been awhile.
Yeah....Kitchen renovation and working at the same time tend to take up your spare moments.
Old 06-08-2016, 08:36 PM   #714
62stepside longbox
Ah I see, well it's gotta get done eventually just think about the fancy kitchen you'll have when your finished.
I started to begin tackling the passenger cab corner today, I cut the skin off and here is what I'm going to be dealing with. It's a tad bit worse than the drivers side, I'll start work on it tomorrow
Old 06-08-2016, 08:38 PM   #715
RANDY COX
RANDY COX's Avatar
Nice work on the cab corner.. Looking good I know what your saying about the heat the humidity is up here making it feel hotter.. Keep up the good work...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 06-09-2016, 01:55 AM   #716
62stepside longbox
Thanks randy. yep the heat has been pretty bad, the past couple days it's been about 36 degrees Celsius so about 100 degrees Fahrenheit
Old 06-10-2016, 12:40 AM   #717
AJCK87
Great job on the body work Nik! Your really getting a eye and a hand for it. Can't wait to see what you do next keep up the good work!
AJCK87 is offline   Reply With Quote
Old 06-10-2016, 01:16 AM   #718
62stepside longbox
Thanks Anthony, in the next couple days I should be starting be axle swap, so first thing on the list will be pulling the old axle out and welding the mounting pads to the new one.
Old 06-13-2016, 07:00 PM   #719
62stepside longbox
Hey guys progress will be slow for the next two weeks since I have lots of exams to study for but I brought my rotors in to school today and turned them. They're nice and smooth and look like new, they still have lots of life left on them since the 78 gmc only had about 60,000 miles on it. Here's a before
Old 06-13-2016, 07:02 PM   #720
62stepside longbox
And here they are all finished up
Old 06-13-2016, 09:11 PM   #721
62stepside longbox
Just cleaned up the hub and painted it
Old 06-13-2016, 11:01 PM   #722
TJ's Chevy
TJ's Chevy's Avatar
Nice!!
Old 06-14-2016, 11:01 AM   #723
62stepside longbox
Nice!!
Thanks tj, all my suspension rebuild parts should be coming soon so I can finally button up the crossmember and get it under my truck
Old 06-16-2016, 08:05 PM   #724
62stepside longbox
Just picked up these brand new replica 39 Ford taillights with blue dots from the local classifieds for $40, and there're LED! These will go on the backs of the rear fenders
Old 06-17-2016, 07:29 AM   #725
Those should look real good!! Nice score.
