Old 06-08-2016, 10:09 PM   #1
Lurayfarmer
Lurayfarmer's Avatar
402 Big block fuel pump
My pump quit suddenly the other day. No big deal, I thought, as replacements are less than $25. The problem? Installation! The pump is sitting in a little cavern surrounded by the block, frame, suspension, hoses, etc. it's barely visible let alone accessible. With a lot of effort I got the bolts loose and dropped the pump. But I could see reversing the process would be a nightmare - and it is. I finally got both bolts started, but I've used every tool in the cabinet trying to crank the bolts into the block. I've tried going from the top but that doesn't help.
Any one else been through this? Ideas?
Shenandoah Valley of Va
1972 GMC 2500 Sierra Grande
402, Custom Camper Package
Lurayfarmer is offline   Reply With Quote
Old 06-08-2016, 10:37 PM   #2
kwmech
Re: 402 Big block fuel pump
Are you sure you got the push rod back up against the cam?
3/8'' pipe plug under the pump usually needs to be removed so you can use a long thin screwdriver to push the rod up and slip the pump in correctly
Old 06-08-2016, 10:44 PM   #3
Lurayfarmer
I will check that tomorrow. It also dawn on me that I probably don't need this style pump with the big tank on it. The pump itself is causing most of the difficulty.
Old 06-12-2016, 04:54 PM   #4
Lurayfarmer
You're right! I wondered what that pipe plug was for.
