Old 06-10-2016, 08:33 PM   #1
Frugalmeyer
1972 Blazer 4WD to 2WD conversion in Texas.
I'll post some pictures of progress during the build.
Frugalmeyer is offline   Reply With Quote
Old 06-10-2016, 08:49 PM   #2
Frugalmeyer
Re: 1972 Blazer 4WD to 2WD conversion in Texas.
Delivered on transport.
Old 06-10-2016, 08:59 PM   #3
Frugalmeyer
Pulling the drivetrain.
Old 06-10-2016, 09:11 PM   #4
Beau2a
Beau2a's Avatar
Subscribed. Congrats on the project.
Beau2a is offline   Reply With Quote
Old 06-11-2016, 01:49 AM   #5
Frugalmeyer
Pulling the 4WD front suspension.
Old 06-11-2016, 01:53 AM   #6
Frugalmeyer
Installing a 1977 C10 front cross member and suspension.
Old 06-11-2016, 02:02 AM   #7
Frugalmeyer
Installing rockers and patch panels.
Old 06-11-2016, 02:06 AM   #8
Frugalmeyer
Removing 4WD rear suspension and brackets and test fitting 2WD rear suspension.
Old 06-11-2016, 02:14 AM   #9
Frugalmeyer
Sanding ,bodywork, welding, bodywork and more sanding.
Old 06-11-2016, 02:21 AM   #10
Frugalmeyer
Setting motor mount perches, motor mounts, transmission mounts, and trimming frame for headers.
Old 06-11-2016, 02:29 AM   #11
Frugalmeyer
Primer, guide coat, sanding, primer, guide coat, sanding. Clean Garage!
Old 06-11-2016, 02:37 AM   #12
Frugalmeyer
Fabricating and final installation of spring perches, panhard bar bracket, shock cross member and rear control arm cross member. Drop off to get sand blasted and painted.
Old 06-11-2016, 05:59 AM   #13
gringoloco
A guy with a truck
gringoloco's Avatar
Making it look easy! From experience, if you are planning on going low, nix the x-member that tied the old spring perches together, as it will cause driveshaft interference.
If you have them, please post your measurements for front and t-arm crossmembers, lots of folks ask the question here frequently.
Keep up the good work!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-12-2016, 03:23 PM   #14
Frugalmeyer
Touch up original undercoat and paint under body.
Old 06-12-2016, 03:42 PM   #15
Frugalmeyer
Seal, paint and clear coat firewall.
Old 06-12-2016, 04:32 PM   #16
truckster
truckster's Avatar
I know this might be taken as offensive by some, but it's really not meant to be: Why? What I mean is, why take a 4 wheel drive and make it what I would consider to be less capable? I know it's a popular conversion, but being a guy who sold his 2 wheel drive trucks and saved up to buy a 4WD Blazer I always wanted, I have a hard time understanding it. I'm not knocking it, I just would like to understand the reasoning.
And by the way, your skills look to be first-rate. It looks like a great job.
truckster is offline   Reply With Quote
Old 06-13-2016, 06:06 AM   #17
notsolo
notsolo's Avatar
X2 on making it look easy, Great color choice too...What are your plans for the rear shocks?
notsolo is offline   Reply With Quote
Old 06-13-2016, 09:45 AM   #18
4oldcars
4oldcars's Avatar
To Truckster: same reason some people drive Fords
4oldcars
Driving:
1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado
The ones I let go:
1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed
4oldcars is offline   Reply With Quote
Old 06-13-2016, 12:32 PM   #19
truckster
truckster's Avatar
I hope nobody thinks I'm slamming Frugalmeyer's truck (or anyone else's) because I think he's done a great job on it. And I don't even hate Fords (Mustangs in my Z28's rear view mirror are a favorite sight).
I guess I'll chalk it up to some people like Pepsi and some like Coke, and that's just how it is.
Still, a very nice truck.
Old 06-13-2016, 01:38 PM   #20
lolife99
67-72 parts collector,…
lolife99's Avatar
Probably did the conversion because factory 2wd blazer are CRAZY expensive.
This is definitely the way to do it if you have the skills needed for the conversion.
Keith
Convert to disc brakes.
Old 06-13-2016, 03:05 PM   #21
Big Block
Big Block
Big Block's Avatar
Not only crazy expensive. Limited supply. Low production numbers to begin with. I have both. Best of both worlds. The 2 wheel drive slammed down hot rod and the 4 wheel drive beach cruiser. Love them both.
Big Block is offline   Reply With Quote
Old 06-14-2016, 10:52 AM   #22
gringoloco
A guy with a truck
gringoloco's Avatar
So nice! What's the color?
-Chris
Old 06-15-2016, 09:07 PM   #23
Frugalmeyer
notsolo
I purchased the shock relocation kit (lowered trucks) from Performance Online and modified and installed a shock cross member from a 2WD truck.
Old 06-15-2016, 09:12 PM   #24
Frugalmeyer
gringoloco
I found pictures of factory blue trucks and found a couple i really liked but could not get them to tell me exactly what color is was. I ended up picking BM132 from the Dupont Blue Metallics. I want to start a thread with pictures of blue trucks and they can only post if the have the paint code!
Old 06-15-2016, 09:15 PM   #25
Frugalmeyer
Getting the motor cleaned up and ready.
