Old 06-11-2016, 02:17 AM   #1
ck5566
Manuel to Power Steering
I understand the changing out of the Gear Box's and the strg. pitman arm but what needs to change from there up to the strg. wheel? speaking of the Column. Mine has a one piece strg. shaft, I think I read somewhere that Power strg setup has a two piece shaft? thanks in advance
ck5566 is offline   Reply With Quote
Old 06-11-2016, 05:43 AM   #2
Thunderwoody
Re: Manuel to Power Steering
You can take it apart at the rag joint. That's what I did to my 68
Thunderwoody is offline   Reply With Quote
Old 06-11-2016, 11:53 AM   #3
70STOVEBOLT
70STOVEBOLT's Avatar
Nothing else needs to change. I have a 67 column in my 70 and its one piece. I simply swapped the gear box and pitman arm.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 06-11-2016, 08:05 PM   #4
ck5566
A long time Member & friend here "________" told me he has never seen a single shaft from these trucks always has two shafts that he has ever seen from these trucks and he has been Parting these for 25 yrs. On my 1st drawing from the rag joint towards the strg. wheel between the 25" and 5" is where he says it comes apart. Any body else want to take a Swing at this. Here is some pics. thanks in advance
Old 06-11-2016, 09:07 PM   #5
frankslagoon
That's a two piece shaft. just heat the bottom part of the shaft where the those two little holes are filled with epoxy a little bit and the shafts will slide apart. this will allow you to slide the bottom piece up to the correct length. Then either weld it or my choice is to drill a 1/4 inch hole all the way thru and put a good bolt through it.
frankslagoon is offline   Reply With Quote
Old 06-11-2016, 10:05 PM   #6
ck5566
I understand it has a collapse'able lower shaft. Again 1st drawing at where the 25" & the 5" marks meet is where I was told it separates from one another. Can anybody confirm this or show me some pics of a power strg. column if there is such a thing.
Old 06-11-2016, 11:48 PM   #7
frankslagoon
Here's a power steering column you can see #25. that's the coupler your talkin about. Bros 70 is factory power steering. here's a pic.
Old 06-11-2016, 11:49 PM   #8
70STOVEBOLT
Ok, technically it's a two piece shaft, because it has the collapsible mechanism. Mine is just like yours. Like mentioned above, take it apart at the tag joint and replace the manual box with the power box and mount and plumb the pump and you're done.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 06-11-2016, 11:53 PM   #9
70STOVEBOLT
The pic that frankslagoon posted shows what I call the two piece shaft, it has the joint just below the column housing and the short shaft that attaches to the rag joint.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 06-11-2016, 11:57 PM   #10
frankslagoon
X2. So there is a difference. but nobody changes the columm ass. when they add power. interesting.
Old 06-13-2016, 02:15 AM   #11
ck5566
Any body else want to take a swing at this, don't be shy speak right up or type it right up.
Old 06-13-2016, 07:53 AM   #12
70STOVEBOLT
My 70 with manual steering and a 3OTT was like the pic that frankslagoon showed, from the factory. When I converted to an automatic trans, I used the column from a 67 because it came with the transmission. I then converted to power steering later using the same column, which is like yours. It is a straightforward swap, just replace the manual box with the power box and install/plumb the pump, unless you are concerned about factory correct, then you may need to change the column to the style in the pic that frankslagoon posted. What year is your truck?
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 06-13-2016, 10:34 AM   #13
nuke82
nuke82's Avatar
I went through the same thing on my truck. I had a non-tilt one piece steering column with a mechanical steering box. The one piece steering columns look like they are two pieces but do not come apart at the top.
I went to the salvage and got a power steering box with pitman arm as well as the collapsible steering shaft then bought a CPP tilt steering column. I regret the CPP tilt steering column, real low quality but it was the same price as what the salvage yards wanted for old worn out tilt columns that were the wrong color.
72 Chevy C-10 w/ 67 front clip
355 ci Vortec
79 Lincoln Versailles 9" rear end, 390 gears
700R4 tranny
McGaughy's 2.5" Front Drop
Fatbar 4-Link
nuke82 is offline   Reply With Quote
Old 06-13-2016, 10:35 AM   #14
ck5566
68 C10 with little to no options.
Old 06-13-2016, 10:46 AM   #15
ck5566
Yah I get the CPP parts thing. I bought also a tilt column 3 x's and sent back 3 x's. Came an open box with missing parts and looked cheaply. Later found it was made in CHINE wow don't you just hate those words China made.
Old 06-13-2016, 10:55 AM   #16
midniteblues
midniteblues's Avatar
I don't know if this is a pic of your truck or not. But that is a manual transmission (3spd) colum that someone rigged to work on a automatic trans.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 06-13-2016, 05:22 PM   #17
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I used to factory 3ott column and a 76ish? power steering box. Everything bolted up in the stock location with no adjustment. I did use a Rag joint repair kit and replace the "rag" part of the joint since both from the parts I used were worn and 40 years old.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 06-13-2016, 05:55 PM   #18
palallin
I had a '67 w/Manual steering. I bought a stripped '70 that had PS from factory. I unbolted the manual box and bolted the PS box into place. Reattached the rag joint and the Pittman Arm. I bolted the PS pump/brackets from the donor onto the engine and the reattached the hoses. Then I drove away. It was just that simple.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 06-13-2016, 07:51 PM   #19
nuke82
nuke82's Avatar
I agree palallin, these are pretty simple. I helped a friend with his power steering on a 66 Mustang and the complexity made my head explode.
355 ci Vortec
700R4 tranny
Fatbar 4-Link
Old 06-13-2016, 10:49 PM   #20
ck5566
This is what you get when Past Owners think with there (well I will keep it clean here) a$$ or the brain they were born with (oooo) that's nothing. Not real fun spending a hole lot of money fixing STUPID stuff!!!
Old 06-13-2016, 10:52 PM   #21
ck5566
Great thats what I am looking for, simpleness.
Old 06-13-2016, 10:54 PM   #22
ck5566
Looking forward to at least one thing going easy for me>
Old 06-14-2016, 10:14 AM   #23
midniteblues
Sometimes we wouldn't have any fun fixing these old trucks if it weren't for the creative minds of the po's
